Previous in Forum: Banner B3-1500 Problem   Next in Forum: Current Control And Pulse Control
16 comments
Voltage Between Neutral & Earth
03/25/2011 9:45 PM
I am getting 230 v between neutral and earth in a cummins 35kva generator. is it ok. if not what could be the reason? and what is the remedy. The generator is earthed with an earth pit but at about 100 mts away near the load.
Re: Voltage between neutral & earth
03/26/2011 1:25 AM
#1; maybe one phase is grounded through your load. perry
Good Answers: 181
03/26/2011 2:24 AM
What voltages are you getting to earth for each of the phases?
Good Answers: 445
Re: Voltage Between Neutral & Earth
03/26/2011 5:11 PM
Does your generator have a floating neutral or is it bonded directly to the frame of the equipment? It is important to distinguish between the equipment safety ground (bonding) and the electrical system neutral (possibly current carrying).
Good Answers: 140
03/26/2011 6:53 PM
Describe the genset. Is it single or three phase? What are its normal voltages supposed to be? You have not given us enough data for any meaningful answer.
03/26/2011 11:11 PM
Where is the 230v, at the generator, or 100meters away at the load.....?...?
Your neutral could be open, and showing a reading because of capacitance...!..?
Cheers
Mark N.
I dislike "Anonymous" intensely. It is like they have something to hide? Their Cowardice.! I also dislike those Who will not help themselves, by not replying, to a civil Question.
03/27/2011 11:00 AM
Would that be a super-dooper DVM or a cheap-and-nasty moving coil voltmeter? That sort of reading on a DVM may simply be an indication that the neutral is not earthed at the generator and that there is an earth leak somewhere on one of the three phases near the load. Does a filament lamp light when it is connected between neutral and earth <repeat question; previous applicants need not apply......>
03/27/2011 11:56 AM
I do believe that earth and the neutral should only be bonded at the generator. The frame should/could be physically earthed with an earth pit, which is to my mind a really great idea......
I do feel that 100 meters away, that if its showing such a large voltage difference that probably something is wrong. But I am fully prepared to be wrong as well!!
If the loads are fairly evenly distributed (if 3 phase), you should only see a few volts of difference between neutral and earth even 100 meters away......I reckon that you have a wiring or cable fault......
Warning, it could also be dangerous!
03/27/2011 12:09 PM
First: take a 240V lamp and connect between the neutral and Earth to see if it will glow If the blow is visible (or you can check the amps), then you have a fault downstream (i.e. on the load side), between a phase and earth.
The normal methoad is to have the neutral from the generator, grounded to a separate ground, as near as possible to the generator. The grounding of the generator metal body is a separate earthing from the neutral. there should be a protective system that will shut down the alternator if there is a leak from the output phases to the chassis of the genset.
If your case is well understood, you have a missing connection between the neutral point at the genset and the ground, AND you have a possible fault on one of the phases, leaking to a ground link somewhere on the load circuit. The fault could be resistive, or through some device like a transformer or lights circuitry, with one end grounded either by mistake or because of an insulation fault...
03/27/2011 12:26 PM
Its dangerous. Have it checkedby an qualifid electrician. Thwere may be leakage.
03/27/2011 1:22 PM
The generator should be grounded at the generator. This establishes the voltage reference point for the system. The distribution panel(s) should also be grounded at their location. This ensures that the entire system is operating with the same zero-reference. Is the Neutral bonded to the frame of the generator? If not, it should be as this constitutes a "seperately derived system". See article 250.35 of NFPA 70.
03/27/2011 1:43 PM
The Neutral point at the Generator should be grounded and preferably at a separate groung from the generator body's ground. This will allow you to install a tripping device in case of a generator internal fault and prevent a fire or much bigger damage.
03/27/2011 10:32 PM
As usual, Anonymous is showing their ignorance, or is it arrogance.
This is the last time anyone should try to help an "Anon".
They will/do not even try to help themselves with a simple reply.
Sincerely.
Mark N.
03/28/2011 6:41 AM
Yes
At least he should respond to one of the comments that are trying to help him!
Well, from the start, his entry shows that he is ignorant of the minimum required to be doing anything near a genset, or trouble shooting it.
The best response is either to ignore such OPs, or just send them to get professional help. This particular one seems not interested in the answers he got or unable to understand them...
03/28/2011 10:09 AM
I am sorry gentlemen. I was away and not able to read the great suggestions. I am checking the system for possible ground falult. The system neutral is earthed separately. But I am not sure the condition near the genset. I will get it checked up as well. Thank you for all the help. I will come back and post the identified problem. Regards.
United States - Member - Preserve and protect...
03/28/2011 9:50 PM
GA because you responded.
Our "colleagues" - although knowledgeable and caring - are apparently somewhat short of patience.
Regards,
Gene
Pessimists are rarely disappointed; optimists are rarely celebrated; pragmatists are neither pessimists nor optimists, and are therefore never wholly right or wrong. -- Anon
04/07/2011 4:18 AM
Mark N, I know that you do not want anyone to help, but there is a reason to help.
He has asked for assistance, in some cultures, it is very embarrassing to respond, that may be the reason for no responce, mind you I have not come across it several times, only ocasionaly, and not on this forum. The preson may be embarrased about the real reason for the fault, dont be to hard on the guy.
Anyway for my uninformed guess as to why you get 230 volts between N + E is because the generator should have its own earth stake and be bonded with the netural, as this is a supply not a sub circuit
Regards
Joe
Reply to Forum Thread 16 comments
Andy Germany (1); euhodos (1); Gazu (1); hc82437 (1); Joe Sparky (1); kishoreholla (1); LAA_Lucke (3); Markone (2); North of 60 (1); perry (1); PWSlack (1); RAMConsult (1); TonyS (1)
