Hi every one,
I have a switch rated for 17 Amps @ 125 VAC and 6 Amps @ 600VAC.Since the power dissipation of the contacts is depended only on the contact resistance and current (Current squired times contact resistance), what happens if I use this switch in a 17 Amps, 600 VAC application? Once installed, the switch may be used to turn ON and OFF the load only a few hundred times in its service time (About ten years). I realize that the arcing when breaking 17 Amps at 600V will be a lot more than when it switches the load at 125 VAC. The load is resistive (Heating element).
Thank you very much, in advance, for the help.
Job Thykkoottathil.
