Previous in Forum: Easy to Flake Floors   Next in Forum: Solid Modelling
Is A106 a Cast Pipe
03/28/2011 6:50 AM
As A 106 gr B pipe is made of Ingots which is made of casting,so why A106 pipe is notr called as cast pipes, as the raw material used for making pipe is casted ingots.
Re: Is A106 is a cast pipe
03/28/2011 7:34 AM
A later process is perhaps more relevant than an earlier process. In particular, a later non-casting process for making pipe might render irrelevant an earlier ingot-casting process for the raw material. (Just a guess.)
Re: Is A106 a Cast Pipe
03/28/2011 2:23 PM
which is made from iron Ore. So why these are not called hematite pipes?
Did you study the total process of pipe making ? There are some very important steps which makes the pipe what they are and not cast cylinders.
Good Answers: 243
03/28/2011 10:46 PM
Both great answers guys. oP, the term cast is not valid as a product descriptor for the pipe, since it was not cast into final shape the ingot was cast ino its shape, then rolled (wrought or shaped) in a rolling mill into an rb (round billet) was then wrought by piercing and rolling into final seamless product.
these days ingots are rare, most likely was continuous cast bloom or billet originally.
The pipe was rolled(wrought) into final form, not cast into it. Therefore it is not a casting.
milo
Register to Reply 3 comments
Anonymous Poster (1); Milo (1); Tornado (1)
