Previous in Forum: ASME PWHT   Next in Forum: Flow through open channel
14 comments
Bolts
03/29/2011 6:52 AM
Hi!
I am using two M30 bolt of 8.8 grade to take the load of 6 tons by means of two rollers as shown below. Now i wanna know whether these bolts will bear the shear stress or not.
Good Answers: 15
Re: Bolts
03/29/2011 7:13 AM
Here is site that gives you enough information so you can do the calculations.
metric fastener data
downhill slide to 112 (damn memor.)
Good Answers: 53
Re: Bolts
03/29/2011 7:21 AM
What is the shear strength of grade 8.8 material?
You can use formula-
Cross sectional area of bolt x shear strength of material x Number of bolts you are using
Please note force must be distributed equally on both the bolts.Probably bolt manufacturer can also tell you shear strength of M30 bolt.or you can have a look on machinery handbook.
Re: Bolts
03/29/2011 7:43 AM
I assume your 6 ton load is not a metric ton since you did not use metric ton as your units. With that being said, then the load would be 12,000 lbs.
If all the load were in just a single bolt (30 mm dia = 1.18 inches) then the shear load would be 10,953 psi. (To be conservative I used this single shear case as opposed to double shear which would be more likely).
According to "Fundamentals of Machine Component Design" by Robert C. Juvinall, an M30 grade 8.8 bolt has a yield strength, Sy, of 660 MPa (or 95,725 psi).
The distortion-energy theory estimate of shear yield strength, Sys = 0.58*Sy = 0.58*95,725 = 55,521 psi.
So I say, yes the two bolts you have would be sufficient to support the 6 ton load. And if the load is in metric tons (6 metric tons = 13,200 lbs), the M30 bolts would still be able to support it.
J B
Re: Bolts
03/29/2011 7:45 AM
How big is the lower bolt near the bottom of the frame?
Each of these three bolts has two shear planes to help support the load.
Good Answers: 101
Re: Bolts
03/29/2011 12:01 PM
If it were my design, I would make sure that the load can easily be supported with one of those two bolts by itself, as it will be impossible to ensure that the load will always be evenly distributed. Depending on the situation, one bolt could be supporting the entire load momentarily while the other is supporting nothing. But I tend to over design everything I design with large safety factors, especially when the supported load has any potential of causing harm if a component failed. Good luck, be safe, have fun & make it work! Cheers!
Re: Bolts
03/29/2011 11:48 PM
When you are in a price competitive situation, you don't dare over design or the $$ go up and you lose the bid!
Lehman57
Good Answers: 101
Re: Bolts
03/30/2011 12:41 PM
I would gladly loose the bid if I thought I would need to design an unsafe piece of equipment to get it. I'll let some other fool get the job, kill someone, and go to court. I turn down unsafe work all the time, day and night, Everyone wants it cheep, which is OK as long as you are not compromising safety. A single lawsuit can ruin your career, your business, and your reputation. luckily, I have never experienced one directed at me, but I have seen people loose it all because of a cheaply designed project that fails.
Re: Bolts
03/29/2011 11:45 PM
It will make a large difference in the allowable stress whether the threads are in the shear plane or not.
Lehman57
Good Answers: 181
Re: Bolts
03/30/2011 2:49 AM
I take it this is a beam runner. If so you need to base your calculations on 3 bolts as you can't guarantee all 4 wheels being in contact.
Re: Bolts
03/30/2011 5:37 AM
There is no need to know.
Refer the entire matter to the facility's Engineer/Surveyor for the company providing lifting equipment collapse indemnity insurance cover. Follow the advice given on the periodic inspection reports from this source, which will be in the facility's General Register.
Re: Bolts
03/30/2011 3:03 PM
Dont forget to do the same calculations on the plate that you will be hanging the 6 ton from eg leave enough"meat" around the holes to carry the weight
Re: Bolts
03/30/2011 6:54 PM
I add a doubt to Zahidlala's: Is possible in his case an extreme shear stress to breake the bolt or a flex effort is what you should expect? Is not distance between bolt bearing something to take in account? or,or? Shouldn't be taken the bolt size directly from a table,i mean empirical data from a machinery handbook? Is really right calculate that in such way?.-
Re: Bolts
03/30/2011 9:15 PM
There are many ways to approach solving a bolt problem such as this. The factors you mention would be significant if one wanted to choose the smallest bolt for a 6 ton load...or to determine the largest load the two M30 size bolts could support. However, that is not how the OP phrased the question.
The question posed was could the two M30 bolts support a 6 ton load as depicted in the diagram. I chose to simplify the problem yet in a conservative way such that the answer did not depend on information not provided in the OP. By showing a single bolt could withstand more shear stress than a single bolt loaded with 6 tons would generate, it should be obvious that two bolts would be able to support the same load.
J B
Re: Bolts
09/26/2024 9:41 AM
These are 15/16" BSW. The applied vertical load can exceed 10T.
Register to Reply 14 comments
ddk (1); ferquiza (1); Grochy (1); JBTardis (2); Lehman57 (2); PWSlack (2); rakesh_semwal (1); RVZ717 (2); TonyS (1); Tornado (1)
You might be interested in: Bolts, Conveyor Rollers, Printer and Copier Rollers
