Previous in Forum: Pressure Vessel Nozzles   Next in Forum: 24"- 2500lb Blind Flange Design (Urgent)
Boiler Drum Material
04/12/2011 3:00 AM
Hi all, i would like to have your Valuable advice on the below mentioned matter.
The suitability of service of SA516-Gr.70 material over A387 steel grades for steam drum and water drum. (steam conditions @ 12.5BarA_ saturated, 65T/Hr)
Thanks and Best Regards
Re: Boiler Drum material
04/12/2011 5:54 AM
SA516 - Carbon steel for low/moderate temperature service. (If I remember, the temperature range is upto about 650 deg F (350 deg C)
A387- Cr Mo Steel - Creep resistance - the temperature range is considerable higher depending on class may go upto 1200 def F (650 deg C)
What is your service temperature will decide whether you are permitted to go for 516 or not (Finally the ASME code will win)
Re: Boiler Drum Material
04/13/2011 3:17 AM
Check the code applicable in your country it will give you all the information you need
If you can't cross the river, use the water to irrigate your side, the grass will soon be greener
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
04/13/2011 4:56 AM
Hi,
If you have 12.5 barA pressure and saturated steam, the temperature must be around 190ºC (374 F), so SA516 Gr 70 is enough for that conditions.
Regards
04/13/2011 6:18 AM
SA516-70 should be able to handle this moderate temperature. SA515 can handle even higher temperature. I think SA387 has chromium (?) in it, which would add to corrosion resistance.
04/14/2011 5:55 AM
At our oil refinery, we used to use:
• ASME SA 516 Grade 70 is a carbon steel plates for moderate and lower temp. service, preferred in fabrication of pressure vessels in steam generation plants, and
• ASME SA 515 Grade 70 is a carbon-silicon steel plates for intermediate and higher temp. service, preferred in fabrication pressure vessels, and
• ASME SA 387 Grade 11 (1.25 Cr & 0.5 Mol) and Grade 22 (2.5 Cr & 1 Mol) is alloy steel plates, chromium-molybdenum, preferred in fabrication of pressure vessels used in storing and handling of hydrogen.
04/18/2011 2:26 AM
Thank you very much Sir, Spot on answer.
This is exactly what i was after.
Register to Reply 6 comments
Abdel Halim Galala (1); Anonymous Poster (1); boilertrainee (1); Kwetz (1); Lancoz (1); Tornado (1)
