Previous in Forum: Weld HDPE Pipe PE 100 and PE 80   Next in Forum: Boiler Drum Material
Pressure Vessel Nozzles
04/12/2011 2:36 AM
Can a pressure vessel have nozzles of different pressure ratings? say one nozzles of 4" 300# and other 4" and 600#. Material of the other nozzle may be different? please comment.
Good Answers: 137
Re: Pressure Vessel Nozzles
04/12/2011 5:33 AM
As long as none of them is rated for less than the vessel max working pressure (or preferably design pressure if higher, to be on the safe side) I don't see why it matters if some nozzles are rated higher.
Also, for comparison with vessel design pressure, don't forget that a 300# nozzle is rated for 300 psi at some elevated temperature and is good for something like 2 x that at ambient temp. Details available on the web.
Cheers.........Codey
04/12/2011 10:39 AM
Please explain why this is necessary.
Is this required because of material availablity ?
Good Answers: 137
04/12/2011 11:25 AM
Why is what necessary? I didn't say anything was necessary, I said what I think is possible/allowable i.e. having different flange ratings, provided the lowest rating is high enough.
04/12/2011 11:42 AM
Suppose that a nozzle on a 300-psi vessel feeds a 600-psi booster pump. It might be handy to make the nozzle flange to 600-psi dimensions for attaching to the pump.
Good Answers: 137
04/12/2011 2:40 PM
That's if the pump suction is 600#. Also IMHO it's not a good idea to bolt a pump suction directly on to a vessel flange, and I don't think I've ever seen that done. If there's a pipe in between, the flanges can be any rating the meets the pressure.
04/13/2011 8:50 PM
Dear Mr. Shanii,
YES - as long as the stress does not exceed it is OK. But for higher class material cost will increase.
DHAYANANDHAN.S
Register to Reply 6 comments
Anonymous Poster (1); Codemaster (3); dhayanandhan (1); Tornado (1)
