Previous in Forum: Boiler Drum Material   Next in Forum: Elevated Temperatures
35 comments
24"- 2500lb Blind Flange Design (Urgent)
04/12/2011 7:09 AM
Hello,
I am working as a pressure vessels engineer. This is my second year.
Today I have recived an e-mail where someone asked me that if I could check the blind flange for testing the pipe lines reactors or something similar.
I don´t Know how to calculate this blind flange and the design parameters required.
I only have those data:
  • 24"-2500#-RF (But, there aren´t any standard flange for 2500#-24")
  • C.S
  • P = 412 bar
  • Tª = Amb.
I think that i need all the data from the flange, cause this flange is not a standard one.
Sorry for my english.
Thanks in advance.
Kike means "Enrique" a typical name from spain
Re: 24"- 2500lb Blind Flange Design (Urgent)
04/12/2011 7:41 AM
  1. Engineering isn't about "urgent" - it's about "considered".
  2. To work in a field where insufficient knowledge is available to carry out an assignment can turn a long-term contract into a short-term one.
  3. To rely on an anonymous response from an international forum does not absolve the original poster from liability should the installed equipment perform otherwise than according to the design.
  4. If in doubt, test it.
04/12/2011 8:46 AM
5. If not in doubt, test it.
04/12/2011 9:25 AM
Thanks, but i am looking for practical advice. Not a philosophy lessons.
Good Answers: 19
04/13/2011 4:52 PM
That was practical advice!!
04/12/2011 7:35 PM
I'm with you mate.
04/12/2011 8:13 AM
I can't explain how to design a blind flange, instead i can give you an ASME reference.
ASME BPVC Sec-I, PG-31.
This will help to find out the minimum thickness required for your blind flange.
Thanks and Best Regards
04/12/2011 11:21 AM
412 bar x 14.7 ≈ 6056 psi. How would a Class 2500 flange work for this? After temperature is considered, maybe a Class 6000 flange?
04/12/2011 11:31 AM
Also for me is "weird"... but, those are the data.
Tª = Amb
04/12/2011 11:36 AM
If somebody furnishes weird data, then somebody else needs to challenge it. (I hope that isn't too "philosophical".)
04/12/2011 12:44 PM
For hydro test purpose (Non shock Load), ANSI 2500# rating flange can be used upto 6170 psig up to 100 °F. For your ready ref. a table is attached.
Maximum allowable non-shock pressure (psig) and temperature ratings for steel pipe flanges and flanged fittings according the American National Standard ANSI B16.5 - 1988.
Maximum Allowable non-shock Pressure (psig)
Temperature
(oF) Pressure Class (lb)
150 300 400 600 900 1500 2500
Hydrostatic Test Pressure (psig)
450 1125 1500 2225 3350 5575 9275
-20 to 100 285 740 990 1480 2220 3705 6170
200 260 675 900 1350 2025 3375 5625
300 230 655 875 1315 1970 3280 5470
400 200 635 845 1270 1900 3170 5280
500 170 600 800 1200 1795 2995 4990
600 140 550 730 1095 1640 2735 4560
650 125 535 715 1075 1610 2685 4475
700 110 535 710 1065 1600 2665 4440
750 95 505 670 1010 1510 2520 4200
800 80 410 550 825 1235 2060 3430
850 65 270 355 535 805 1340 2230
900 50 170 230 345 515 860 1430
950 35 105 140 205 310 515 860
1000 20 50 70 105 155 260 430
04/12/2011 4:37 PM
Thanks Mukesh,
I know that. The problem is that I need to design the blind flange. ASME hasn´t got a standard one, the last standard is for 12".
Tomorrow i will have more data such as: BCD, THK, etc. For design the blind flange i need to know all the parameters of the flange.
04/12/2011 5:14 PM
I want to say something off-topic:
One person told me something about my name so:
Here in Spain Kike means "ENRIQUE". Is more or less the same than:
jonathan---->john
04/12/2011 4:58 PM
You might consider petitioning CR4 administration to alter your name.
In english, your name is a pejorative word for a Jewish person. That is to say, it is a demeaning or derogatory Anti-Semitic slur.
I doubt this is what you had in mind when you selected it, but it may very well prove troublesome for you.
04/12/2011 5:13 PM
Here in Spain Kike means ENRIQUE. Where is this petitionig?. Is more or less the same than:
jonathan---->john
04/12/2011 6:44 PM
OK, I understand what you mean:
In Spain, Enrique---> Kike, as in English Jonathan----> John
And I see you have noted in your signature line a brief explanation. As I said, I believe you did not know, and do not intend to offend anyone. It is simply your name. Fair enough.
And, I welcome you to CR4.
04/13/2011 12:39 AM
ASME BPVC PG-31 Unstayed flat heads and covers
04/13/2011 5:48 AM
Thanks for all the comments.
I have solved the problem.
Blind cover requires THK = 300 [mm]. I used "COMPRESS" for do the same flange that exist on site and then I designed the flat/bolt cover.
I have had many problems , because, I had not enough data (the flange was not a standard one), the flange is a Ring Type Joint, and the cover flange that people on site wanted to attach was a raised face.
It was interesting.
04/13/2011 8:22 AM
Check for gasket requiremnet also. For that high pressur, I think you will need a ring gasket which will be metallic.
Regards;
Nadeem
04/13/2011 8:40 AM
Thanks Nadeem,
I used a Mineral Fiber with Binder 1/16 in. Thick; m = 2.75; y = 260.136 kg/cm^2; width = 50 mm.
04/13/2011 9:26 AM
I suspect this gasket will blow out and could hurt or killl someone. The flange should be designed to use a Spiral wound (m=2.5 for carbon steel or 3 for others & y=10000 psi) or Ring Joint (m=5.5 to 6.5 & y=18000 to 20000 psi).
04/13/2011 10:09 AM
That high pressure and size, I am sure he will need a ring joint metallic gasket.
He said he solved the problem but I doubt it as there is more to the design of this blind flange he is looking at.
Regards;
Nadeem
04/13/2011 11:21 AM
You're right. I checked the calculation and is spiral-wound metal gasket.
Anyway, my supervisor will review and comment me.
Thanks.
04/13/2011 10:49 AM
As far as I know, "k" is not a native letter in the Spanish alphabet. As in French, it seems to be used mainly for foreign words (kilowatt, etc.) This make me wonder if "Quique" might be a better rendering of the nickname for "Henrique." If nothing else, this would save you from explaining "kike", which in some contexts is a derogatory term for "Jew." Just a thought.
04/13/2011 11:12 AM
Ok, the correct form in the correct spanish (RAE) is Quique, but, an informal way is Kike...
As far i Know, Enrique is without H.
I will Change my name.
Thanks
04/13/2011 8:34 AM
300mm is not credible for this blind flange. 30mm is likely to be closer, but that is only a guess.
04/13/2011 8:52 AM
Thank Tornado,
Take into account that this cover is subjected to 412 bar at Amb. temperature for the Test.
The reactor conditions are: P = 185.5 bar; Tª = 453. The Flange attached to the Reactor has a Thick = 262,5 [mm].
I checked the data sheets as You told me. I checked also the P&ID. All is ok.
Hobbies - CNC - New Member
04/16/2011 3:22 PM
So this flange is a touch over ten inches thick! That's barely plausible to me, but the idea of putting a raised face flange against a ring joint flange and expecting a Garlock gasket to hold 6000 psi on hydrotest is one I would put odds against working. Machine a matching groove in your blind flange, and obtain the proper ring and bolts. I'm sure that two foot B7 studs can be gotten, but you had better get the ring, studs, heavy hex nuts, and wrenches ordered now, then see about finding a machine shop to fabricate this monster blind. I'm a retired steamfitter, so have a more rule of thumb view than most on this list. Get with your vendor of bolts and gaskets with the measured dimensions of the existing flange, and get the proper ring. You have no chance without it. Bolt dope in both grooves and all bolts, and removal of all burs on threads so that the nuts can be hand tightened to snug. 6000 psi hydrotest is belt and suspenders country.
Good Answers: 34
04/14/2011 5:29 AM
Por favor, atention como dice Mechanicalmark, puede peligroso.
One more thing off topic:
If you know the alphabet in English, French, German or many other languages, you can easily learn it in Spanish.
That is because the Spanish alphabet is very similar to the alphabets of most European languages. According to Real Academia Española, which is considered the arbiter of what's official Spanish, the following letters make up the Spanish alphabet:
    a, b, c, d, e, f, g, h, i, j, k, l, m, n, ñ, o, p, q, r, s, t, u, v, w, x, y, z
In other words, the Spanish alphabet, with 27 letters, is the same as the English alphabet with the addition of the ñ.
04/14/2011 7:25 AM
It´s true, since last year letters LL and CH were deleted so now the Spanish alphabet has 27 letters and k is included.
04/14/2011 9:31 AM
This is OT to the flange discussion, but I enjoy watching the evolution of languages. I remember when ch, ll, (and rr?) were considered as distinct Spanish letters, as ñ still is. Sorry about the H before Enrique; I was mixing my French and Spanish. )
04/14/2011 6:09 AM
If the flange is specified by NPS 24 and Class 2500, at this case the flange is considered a standard, and its dimensions can be easily find out from ASME B16.5. Otherwise, when the flange is non-standard, in this case you can use ASME BPVC, Section VIII-1 to calculate all dimensions and thicknesses.
Please, for a lot of details and free download for a sample of calculation, refer to the following CR4 Thread: http://cr4.globalspec.com/thread/18082/Calculation-of-blind-flange-thickness , Post #10.
04/14/2011 7:21 AM
Thank you very much for your comment Abdel,
I will take a look, i am sure that it will be very useful for improve my knowledge.
For class 2500 and 24" is there (in ASME B16.5) a standard one?. For class 2500, de last standard flange is 12". Right?.
*That flange, wich is attached to the reactor is a non standard flange so I designed (copy from the previous calc) this flange and then I calculated the blind flange.
Be calm, I am a junior engineer everything I do goes through a more experienced engineers.
04/14/2011 11:58 PM
Since Table 22 "Dimensions of Class 2500 Flanges" of ASME B16.5 is not includes NPS 24, so we can assume that flange as Nonstandard, and hence the calculations as per ASME VIII-1 is applicable for both the flange and its blind flange.
04/23/2011 9:42 PM
Obviously -you cannot buy this from somebody's catalog - as a flat Blind Flange.
Better to treat it as a torispherical dished end.
You will get Minimum Mass flanged dished end from Pressure vessel makers
mm
04/24/2011 2:08 AM
Kike
Normally for this size of flange, manufacturers give grooves for Metallic O rings for hydro test purpose. Even though grooves for ring gaskets are there but particularly for hydro test at 1.5 times of design pressure normally V gooves are given on the inner flat surface of the flanges and suitable copper Ring is used for hydrotest.
Register to Reply 35 comments
Abdel Halim Galala (2); boilertrainee (2); Doorman (2); drbobwoolery (1); Kike (12); lyn (1); Mechanicalmark (1); Mukesh0861 (2); MUKULMAHANT (1); Nadeem Butt (2); PWSlack (2); Stedou73ish (1); Tornado (5); Whitephone (1)
