Previous in Forum: Late 1930's Packard Saloons Uncovered   Next in Forum: Is Appearance or Performance More Important in Vehicle Design?
blimp construction
04/12/2011 3:54 PM
i want to build a small blimp(2 m long , 1 m diameter),
but i can't decide which material to use for the envelope
i think polyurethane would be good but i just don't know where to buy it from
i am currently in egypt and i need to find a supplier who can send me the material
Re: blimp construction
04/12/2011 4:02 PM
What gas and payload weight are you planning on using as the material selection will depend on this?
04/12/2011 5:54 PM
i will use helium, and the the bay load is about 1.25 kg
04/12/2011 8:37 PM
There are a number of good websites on the internet that offer guides to Helium blimp construction.
http://www.ehow.com/how_2062990_use-helium-airship.html
Polyurethane may work, but if it is going to be difficult (or expensive) to get you may want to be sure before ordering. Plastic or composite sheet material should be available over the internet from either a plastics manufacturer, supplier or wholesaler (it is not a controlled material).
04/12/2011 8:26 PM
According to the Goodyear Blimp Website, their blimps are made of two-ply neoprene-impregnated polyester fabric.
Good Answers: 21
04/14/2011 6:46 AM
Mono coat is a material that is used in RC aircraft covering processes. Very easy to work with and tough as nails. You should be able to google RC Aircraft and find a ton of suppliers around the world for this type of material.
What are you using the blimp for, if I may ask?
04/14/2011 8:00 AM
i am building it as college project.
06/15/2011 4:15 AM
Here's a link that i think could help you to get polyurethene...
http://www.icis.com/Search/ProductNumber/70118/WorldWide/Polyurethane+(PU)+Resins.htm
Register to Reply 7 comments
ahmadhodeb (2); fixitorelse (1); hobbits (1); jack of all trades (2); Tornado (1)
