Previous in Forum: Is it Possible to Standardize the Generator Transformer Voltage??   Next in Forum: One for the Older Ones
Transistor
04/13/2011 1:37 AM
how does actually a transistor amplifies??????
Good Answers: 145
Re: transistor
04/13/2011 1:49 AM
It switches a large voltage with a smaller one.
Re: transistor
04/13/2011 3:06 AM
Or current
Re: transistor
04/13/2011 3:32 AM
A good analogy which applies to FETs (field effect transistors) is to imagine a soft hosepipe with water flowing through it, by applying a small variation in pressure to pinch the pipe you can control a big flow of water.
Re: Transistor
04/13/2011 9:20 AM
Do also check out the Wikipedia pages on this topic.
Re: Transistor
04/13/2011 3:29 PM
I was once told it was because of magic smoke, that is why when the magic smoke leaks out of the transistor it stops working.
Good Answers: 804
Re: Transistor
04/13/2011 5:08 PM
I always thought a transister was a brother who had an operation and became a sister.
I learn something new every day in here...
Good Answers: 117
Re: Transistor
06/28/2014 12:05 AM
A transistor has three leads, two of which can carry a lot of current, and a third leg which I call the "signal lead". The other two leads have an inlet side (which never changes voltage) and an outlet side whose voltage goes up and down according to what the signal lead tells it to do.
A small change of voltage on the signal lead of the transistor will cause a greater or lesser resistance to be created between the other two leads. That changing resistance will result in a changing voltage drop at the outlet. The amount of voltage drop will vary directly with the applied voltage to the signal lead. That big voltage drop which exactly mirrors the tiny applied voltage is what we call "amplification".
You can never get a higher voltage at the output of the transistor than what you apply to the inlet side.
This was an exercise on my part. It has been years. Anybody think it was too simplified?
Register to Reply 7 comments
Anonymous Poster (1); jack of all trades (1); JRaef (1); PWSlack (1); Tobugrynbak (1); user-deleted-1105 (1); Yusef1 (1)
