Previous in Forum: Honeywell Paperless Recorder(v6 minitrend)   Next in Forum: Cobalt Compound Solubility
18 comments
Canada - Member - New Member
Oil Production
04/16/2011 11:17 PM
Oil producing wells using the gas lift process often have space for a ball catcher on the surface production line. What is a ball catcher?
Good Answers: 130
Re: Oil Production
04/16/2011 11:56 PM
I was going to say :"the most expensive carpet, if a cat is invoved"
But maybe this is more "acceptable" in some circles.
"Launching and Retrieving Head
The launching and retrieving head facilitates the placement of the wiper ball into the smaller-diameter workstring. A ported nipple within the head makes it possible for the wiper balls to be retrieved at the surface if reverse- circulation is required prior to the ball reaching the indicating ball catcher. As a result, the cement slurry can be reversed out of the workstring without shutdown.
Wiper Ball
The wiper ball consists of a 50-durometer nitrile compound. This compound provides the flexibility and durability needed for proper workstring wiping. The wiper balls are available in sizes 2.50 in. (63.5 mm) through 6.3 in. (160 mm).
Operation
Install the ball catcher above the retrievable or drillable packer in the workstring. Run the workstring to the required depth and set the packer. Close the circulating valve of the retrievable packer or sting into the drillable packer to begin pumping operations. Pump spacer fluid ahead of the cement.
After displacing the desired volume of cement into the drillpipe, pump enough spacer to clean the line of cement and drop the last ball. When the last ball is within 10 bbl of the ball catcher, slow the pump rate to 1 bbl/min. for the first 5 bbl of displacement; then cut the rate back to 1/2 bbl/min. for the last 5 bbl.
HAL17722
Re: Oil Production
04/17/2011 3:38 AM
With a "Miss Piggy" face painted on the ball, this could readily be generalized to pipe pigging operations....
Re: Oil Production
04/17/2011 5:48 AM
Hi Tornado,
I dont think so! But thanks anyway.
Re: Oil Production
04/16/2011 11:56 PM
Catching is better than busting.
Your statement indicates that you might know something about the subject.
Your question indicates that you don't.
Check Wiki.
Re: Oil Production
04/17/2011 5:57 AM
Thanks Miss Lyn,
Do you know anything about this subjerct? If you do put it down, if you dont why did you respond to my question???
Nothing to do!!
Good Answers: 130
Re: Oil Production
04/17/2011 7:14 AM
Settle down Chama. Miss Lyn has his foibles, but one day; sooner that you might imagine - he - just might know what you need to know.
Be around a bit longer and you will see there is no rule against a bit of fun, to alleviate the boredom and repetition, of handing out 'free 101 advice' to many, who just haven't learned to research for themselves.
Re: Oil Production
04/17/2011 8:07 AM
Many thanks for you information. I am not a subsurface person so I do appreciate some help.
Re: Oil Production
04/17/2011 10:13 AM
I know as much about the subject as you, which is nothing.
You came here wanting free advice because you are either doing homework or it's part of your job, that you can't do. So, take the bitter with the sweet and just be glad the someone here did your work for you.
By the way, 34point5 found the answer by searching for it, just as you could have done yourself. (I'm giving you the benefit of the doubt that you really are intelligent enough to frame a proper question for a search)
So, get over it and start your own forum, if you want to make the rules!
Have a pleasant day uninformed one.
Good Answers: 130
Re: Oil Production
04/17/2011 10:42 AM
ummmm, big assumption? or 'backhanded complement'?
Do we extrapolate;
A. 34.5 is only 'intelligent enough to frame a proper question for a search'
Or
B. 34.5 your typical dumb-ass who just got lucky by knowing what is was, so where to look for a good source?
Or
C. excreta + fan = ends poorly
Re: Oil Production
04/17/2011 10:54 AM
Neither. Co-lateral damage.
The finely detailed drawing was my first clue that you searched out the answer.
I'm sure that you knew more about the subject to begin with than either I or the OP.
Butt out!
Good Answers: 130
Re: Oil Production
04/17/2011 11:01 AM
Ooh! masterful
AZif
Good Answers: 114
Re: Oil Production
04/17/2011 12:56 PM
Re: Oil Production
04/18/2011 12:17 AM
Oh Lyn your such a bitch!
Re: Oil Production
04/18/2011 12:26 AM
Oh, uninformed one, I just can't help it.
Good Answers: 204
Re: Oil Production
04/17/2011 11:43 PM
I thought catching and receiving the balls (of different sizes) were used to set the fracking zones (depths)
I don't know much.. but saw some of that on a drilling show on the telly.
chris
Good Answers: 130
Re: Oil Production
04/18/2011 2:27 AM
Chris, more from Haliburton
"The foam wiper ball is designed to wipe drill-pipe or tubing
string clean of cement, fluids, or debris, and can be used to
separate fluids.
These wiper balls are made of natural rubber and can be used in a
temperature range of 40°F (4°C) to 302°F (150°C). The ball has a
parting stretch of 380 to 440%, which means it can pass through
small restrictions without being damaged.
The wiper ball can be loaded into drill-pipe or tubing connections.
It easily passes through internal upset restrictions such as
mechanical setting tools, diverters, and liner running tools, and
multiple balls can be pumped if necessary. Foam wiper balls have
been used with all types of drilling and displacement fluids."
Underlining is mine, re the fracking depth set.
So say you want to pump concrete down a pipe full of sea water. If you did it without a ball, then the two would mix, and a slurry mess result.
Similarly if you want a distance or depth; putting a calculated volume of something, behind a ball will put the ball at a distance [given a known pipe area]
Or its a rubbery spherical piglet
Good Answers: 204
Re: Oil Production
04/18/2011 8:18 AM
This represents more closely what my perception was.
I did think the balls were steel.. but I've been wrong before... (just last year)
Cheers
Chris
Good Answers: 130
Re: Oil Production
04/18/2011 11:48 AM
Good explanation of how they work too
nor brass, up there in Canadia
Register to Reply 18 comments
34point5 (6); chama2633 (4); chrisg288 (2); Garthh (1); lyn (4); Tornado (1)
