Previous in Forum: Voltage vs. Current   Next in Forum: ABB PLC mp200 Cards
12 comments
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Color Code for Electrical?
04/20/2011 3:14 AM
Orange for electrical trunking
Blue for water pipe
What other colors for gas, water, compressed air, telecommunication trunking, fire fighting pipe in builbings according to IEC/BS/NEC?
Anything that can go wrong, will go wrong
Re: Color code for electrical?
04/20/2011 4:08 AM
I don't think there is any universal color code for electrical conductors or piping, either one. A lot depends on local regulations and customs.
Good Answers: 266
04/20/2011 7:05 AM
Every country is different in the USA for pipe lines in structures it's set by NFPA. Colors are to identify the hazard of the gas or liquid. You need to get the codes for country that your work is in.
Hobbies - DIY Welding - New Member Popular Science - Weaponology - New Member
Re: Color Code for Electrical?
04/21/2011 5:46 AM
"Uniform Color Code for Marking Underground Utility Lines":
Pink: Temporary Survey Markings
Red: Ecectrical and Lighting
Yellow: Gas, Oil, Steam, Gaseous Materials
Orange: Communications
Blue: Potable Water
Purple: Reclamed water, Irrigation and slurry
Green: Sewers and Drain lines
04/21/2011 5:57 AM
Maybe it's good that color codes are not uniform; I certainly wouldn't want to use that one. Green = sewer; are you kidding or are you f***ing kidding?
04/21/2011 7:43 AM
They Navy uses Gold for Sanitary Waste along Piers and they are referred to as Honey pipes.
SWEET!!
04/21/2011 1:06 PM
Honey pipes??? Are we going too far???
04/22/2011 2:07 AM
This may be a historical/cultural thing. In the days of outdoor privies, no one wanted to go there in the middle of the night, so chamber pots were used. These were also called "honey buckets." ( Some inverse psychology there.) In the U.S., one of the portable chemical toilet manufacturers uses the brand name "Honey Bucket."
04/21/2011 1:04 PM
Those are color for marking not for the paint code. I mean here about the material color code.
e.g RED for fire water pipe. Am I correct? It is a general understading.
06/01/2011 10:52 AM
In our area PVC sprinkler system pipes are orange, otherwise they are black (iron) pipe. I am not up on it enough to know what color PEX sprinkler system pipes are.
04/21/2011 6:34 AM
Where else would you expect "green" gas to come from, the Power Lines?!?!
04/21/2011 6:52 AM
Oh well, maybe it depends on what specific shade of green....
Good Answers: 12
04/25/2011 11:18 PM
Being in Vietnam, I assume that color coding of pipes would be heavily influenced by the French. Does anyone know French standards?
Bill
Register to Reply 12 comments
eric (1); hien.nguyenquoc (2); ozzb (1); Redman46 (2); Sciesis2 (1); Tornado (4); XNuke (1)
