Previous in Forum: New Business in US   Next in Forum: How to make perfact ring from an iron rod or pipe
15 comments
Measuring Density
04/25/2011 8:49 AM
Hello,
Is there anything out there that measures density of a play-dough like material accurately that is not too expensive?
Thank you,
Tom
Re: Measuring Density
04/25/2011 8:54 AM
Triple beam balance and a beaker of water. Actually, any weighing device rigged to support the sample in the beaker will work.
05/11/2011 4:20 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
05/11/2011 7:05 AM
Do these Flowmeters check for density? Plus what we are checking has the consistency of Play dough.
Thank you,
Tom
Good Answers: 114
05/11/2011 8:55 AM
one of the many Spammers that appear from time to time
05/11/2011 4:41 PM
Should there be a new Rule? 3 strikesspam posts and you're out?
(Matey's done at least 4 in a row).
05/12/2011 7:08 AM
Thanks. Looks like it's deleted.
04/25/2011 9:03 AM
Alternatively, weigh the sample in air, and measure the volume by immersion in fluid in a measuring cylinder.
04/25/2011 12:29 PM
If it's soft like play-do, he could simply pack it into a graduated metric cylinder of known volume. First 'weigh' the cylinder empty to get its mass (or zero the scale to eliminate the tare) and 'weigh' it a second time when filled with the gel to get the mass of the gel. No need for water in this case.
04/25/2011 2:27 PM
Simektp was posting this in reference to a question that I had asked him this morning. We have tried that method but the gage R&R fails because the repeatability of measuring it that way is poor. The water seems to work well, but the measurements from the beaker or cylinder are difficult to repeat as well, even at 1ml increments.
Good Answers: 130
04/26/2011 12:56 AM
If you combine Lyn and JD you have the technique.
Weigh a sample suspended on a fine wire, or similar, in air
Fill a measuring cylinder partially with water to a noted level.
Lower the sample to submerged.
Note the new water level and new weight.
New level is the sample volume
New weight is the % change
'Variables' will be temperature, wire volume (if you go too deep) and possibly air inclusions in the sample (so you may wish to vacuum desiccate a "putty" prior).
You should use as large a sample as practical to fit the cylinder - not some tiny piece.
Actual sample size need not be precise, or consistent - just fit freely, not sit on the bottom and not cause water rise above the scale.
04/26/2011 3:55 PM
Why weigh it in water? If you know the weight in air, and the volume (from the cylinder graduations) you have the answer. The difference between this result and your method would only give the error due to the 'buoyancy' in air, which - for a lump of clay - would be negligible compared with the other errors (some of which you've mentioned).
(Why do so many people put quote marks around the word weigh? Is there something wrong with it about which I do not know?)
HEY - ADMIN! - any way of merging the two parallel threads with the same name? - would make life a lot easier for all concerned. I'm pretty sure the two OPs who work together wouldn't mind. (Pretty please? :) )
Good Answers: 114
04/26/2011 4:22 PM
The procedure being described sounds like specific gravity
like this http://www.mineralab.com/Hanneman.html
a couple of other types
http://www.mineralab.com/Specific%20Gravity.htm
04/26/2011 4:34 PM
Spot on - but SG wasn't in the subject line.
OK - if you know one, you can calculate the other - but dry weight and wet volume measurements sound easier to me than trying to weigh something suspended on a string in a bucket.
Good Answers: 130
04/26/2011 9:32 PM
Well Mr Grumpy, it depends (somewhat) on why they want to know (also not clear in the OP). E.g. for development, or QA?
But, by doing it two ways in the same protocol - the results aught to line up. If they don't then there is something wrong with the procedure, or apparatus, or sample - I.e. contamination, or a void (spare parts, cockroaches, ...)
It's just a little foible of mine to build some 'self checking' into test protocols.
Saves a lot of time "chasing anomalies" if you can see a result is "odd", straight off the bat.
04/25/2011 4:38 PM
Aside - why the single-quotes around the word weigh?
Register to Reply 15 comments
34point5 (2); cody304 (1); Garthh (2); JohnDG (5); lyn (1); simektp (2); sureflowmeter (1); Usbport (1)
