Previous in Forum: Measuring Density   Next in Forum: CMM - Coordinate Measuring Machine
India - Member - New Member
How to make perfact ring from an iron rod or pipe
04/26/2011 4:46 AM
Hi every body. please sugest me different different method to make perfact ring from an iron pipe or rode
Good Answers: 18
Re: How to make perfect ring from an iron rod or pipe
04/26/2011 5:24 AM
Hi BinnyGunjan,
Nothing is perfect. You need to specify the size of the material and of the ring but most of all you need to specify the tolerance of the ring diameter.
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Re: How to make perfact ring from an iron rod or pipe
04/26/2011 8:46 AM
Pipe, cut a slice off the end= ring.
Rod, cut a slice off the end and drill a hole of the proper size through it= ring.
Brings up an interesting question. How short does a pipe have to be to be considered a ring, then how flat does a ring have to be to be considered a washer?
04/26/2011 10:28 AM
Foil, shim, washer, spacer, bushing, sleeve, pup, short pipe, long pipe, pipeline.
04/26/2011 5:12 PM
04/26/2011 7:38 PM
I'm thinking the person asking the question is asking how to bend a pipe or rod into a circle. If so, it depends on the diameter required and the size of the pipe or rod. There are machines that will roll pipe or rod into a near perfect circle. It probably isn't possible to do it by hand.
Mr.Ron from South Ms.
04/26/2011 9:11 PM
Try a ring roller (http://www.youtube.com/watch?v=Hw4upaGLRKs)
or a tubing bender (http://www.youtube.com/watch?v=EkBgqv646KQ)
Thin-wall tubing may require a mandrel tubing bender to prevent kinks, or collapsing of the tube.
Good Answers: 119
04/27/2011 5:12 AM
I've had to make sets (>10 pieces) of rings from 1/4" and smaller pipe and rod. The method I used was to wind the material around a mandrel many times to form a tight spiral coil. The mandrel was sized slightly smaller than the required ring because the material would relax when the mandrel was removed. I then cut the coil along one side to produce a uniform set of slightly offset rings. I aligned the free ends and welded or soldered them to form "nearly" perfect rings. Hope that helps.
Register to Reply 7 comments
jesw55 (1); lyn (2); mjb1962853 (1); pantaz (1); ronseto (1); Tornado (1)
