Previous in Forum: Mitsubishi Canter Gearbox M035 T4   Next in Forum: 2006 GMC Sierra Truck Electrical
12 comments
Speedometer is Too Fast
04/27/2011 7:59 AM
i have a 1997 ford ranger and it has the corect size tires on it but the seedo is 10 mph slow. any ideas on what to check?
thanks
Re: speedometer is to fast
04/27/2011 8:04 AM
The sending unit for that truck is probably defective.
http://www.therangerstation.com/tech_library/speedometer.htm
04/28/2011 7:36 AM
Nice link, I just learned something.
Good Answers: 88
04/27/2011 8:22 AM
FIRST check mile counter accuracy at a known distance. If it's OK and 10mph is a constant error in whole range, definitely meter problem, just disassemble and twist lever by 10mph. (You could also mess with biasing on it's Freq to Voltage converter if it's an analog meter). If error is a function of speed AND meter is analog, one could mess with converter's gain. If it's full digital stepper controlled you can safely dispare.
Good Answers: 150
Re: Speedometer is Too Fast
04/27/2011 4:16 PM
following a link on kramarat's link takes you to an area that discusses recalibration of the system. it is entirely possible that the gear ratio in the rear differential has been changed throwing off the calibration.
Who is John Galt?
04/28/2011 12:12 AM
During that year some of the american made autos were produced with wheel
equipment that was set for 55 mph as the constant speed.Could that have worn down
the mph detection system after driving alot faster for a long time.
dsuzmay@gmail.com
Good Answers: 150
04/28/2011 12:58 AM
um, no.
Who is John Galt?
05/01/2011 3:19 PM
Before doing anything, please tell us how you know that the vehicle is showing a 10 MPH discrepancy? The method used may be at fault.
My personal method is to use a GPS with a MPH display and drive on a road that is mainly straight or only very long slight corners. Sharp corners will ruin the accuracy. A straight road is the best for testing!!!
Generally speaking a speedo may show a higher speed than actually being achieved, but never a lower one.
Also maybe your vehicle was originally sold with smaller than standard tyres/wheels.....its possible!!!
05/01/2011 4:20 PM
i went through a road side "your speeds is" set up more than once and my speedometer always reads 10 mile an hour slow. wether it is on the hi way or in town.
Also i have had people follow me with the same results.
Good Answers: 150
05/01/2011 8:20 PM
of course those "your speed is" things are probably calibrated on the low side too... they have an agenda to make you drive slow.
Who is John Galt?
05/03/2011 3:30 PM
Borrow a GPS and find out exactly, then get a workshop to adjust it correctly....
Good Answers: 123
05/05/2011 2:05 PM
Lyn -Door Industries sells peel and stick numbers to recalibrate your speedometer.
Bob
06/17/2011 2:52 AM
Hi guys... some instruments have settings behind the speedo to set up for different wheel sizes or differential ratios etc;.. I would 'assume' it is an electrical system & not mechanical.. also some speedo sender units (down on the transmission) are adjustable with letters/numbers in relation to wheel & diff ratios as well.. check this first.. Is easier than removing instrument cluster.. less swearing involved .heehee....
cheers for now...
A.J
Register to Reply 12 comments
Alhardy (1); Andy Germany (2); AVERAGE JOE (1); bob c (1); ds (1); Fredski (1); kramarat (1); Rorschach (3); SimpleMind (1)
