Previous in Forum: Method to Insulate Existing Slab   Next in Forum: Rainwater in Heating Ducts
21 comments
Hobbies - Target Shooting - New Member Hobbies - Fishing - New Member
Good Answers: 12
Need Tips on Water Flow for Drainage Pipe
04/28/2011 11:29 PM
I installed a 125 foot long, four inch diameter drainage pipe onto a neighbors sump drainage pipe. She sold me the low lying lot she owned. I am in the process of making half of it usable for an orchard. It is a very "wet" lot. It has "ponding" in many areas, much of the time. I estimate the elevation drop to be about six foot. The pipe is flexible corrugated without perforations. My goal is to get her water to the main drain for the lot. I understand that I should have a .8 inch drop, minimum, for every foot of length. That would be about an eleven foot drop.
I seem to be transporting the water. Should I test it with a hose when it is dryer? Right now it is under water due to "normal" side flooding. I will be installing a lot of rock over the pipe to keep it in place and protect it in a shallow trench I have hand dug. It is usually impossible to get any equipment in, due to the soft mud.
Re: Need tips on water flow for drainage pipe.
04/28/2011 11:37 PM
I think the standard for sewers is 1/4" slope per foot, and you have a bit more than that. I don't know if the corrugated pipe requires a larger slope. The worst-case gpm would also weigh into this.
Good Answers: 12
05/07/2011 10:41 PM
I estimated the drop at six foot for 160 feet. That would be 72 inches, or almost half an inch per foot. I was worried about not getting it right, but every little bit is draining well.
Now I discover that the manhole cover size drain, near the end, just feeds into an old three inch drain pipe that appears to have been installed with the holes on top instead of on the bottom. It seems to be, predictably, 90% stopped up. The culvert is about six inches above my "flood plain" so I will just have to wait for the last six inches of water to soak in to lowest areas of the lot, or pump it into the culvert. This is something I can live with though.
I am waiting for a major rain event to test my progress. Your info gave me confidence as I loaded, hauled, and dispersed 128 bags of rock behind my riding mower.
Thanks
Re: Need Tips on Water Flow for Drainage Pipe
04/29/2011 8:25 AM
I don't know if this applies to your situation, but I feel I should mention it.
I attempted to do what you are doing about 6 years ago. After several hard rains and water flows, my pipe filled up with dirt/mud and became completely useless.
Before you get everything buttoned up, you may want to look into using perforated, flexible drainage pipe in your trench, with gravel and a silt screen. Google "french drain". This has the advantage of draining water along the entire length of the pipe, and the screen prevents it from getting clogged.
This doesn't answer your question, but if it applies, it could save you a lot of work, anger and heartache.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
04/29/2011 12:41 PM
That's exactly what I'd recommend.
Line your trench (all the way around) with some type of geotextile to catch silt (such as "silt fencing" material that can be found at Home depot, Lowe's, etc just don't get the biodegradable type), put in some gravel bedding, pipe, cover with gravel. I would use a clean, washed gravel 3/4" to 1" size
The trench/gravel will convey a large quantity of water as well even without a pipe!
Sometimes my thoughts are in a degree of order so high even I don't get it...
Good Answers: 12
04/29/2011 5:44 PM
I am planning to have a gravel " creek" over the pipe. The water comes from all sides. The pipe is just for my neighbors pump and any really high unusual flooding. I have a drain on top of the pipe for that.
Does it make any difference if the pipe is not laid perfectly even, so long as the end is the lowest?
Good Answers: 114
04/30/2011 8:17 AM
you're on the right path using a "creek" for primary surface drainage, so your shovel work will do double duty...
the drain fitting for the flex pipe generally have a silt trap
be careful about the depth if it's too shallow it can become crushed by trucks or other equipment
Good Answers: 12
04/29/2011 5:45 PM
Thanks for the warning.
Good Answers: 203
04/29/2011 11:02 PM
1/4" pitch per ft of run is the minimum slope but is quite acceptable. The best way to install the drain system is: to dig the trench with the correct pitch; place some 3/4" crushed stone/gravel in the bottom of the trench to facilitate flow and drainage below the pipe; install perforated (flexible or non-flexible, whichever is most convenient for you) pipe with the geo-tech cloth (available as "tube/socks" in 10 or 100ft lengths that slips on the pipe) on top of the crushed stone in the bottom; place some more of the crushed stone on top of the pipe (the more the better); and back fill the trench with soil. Avoid placing oversize rocks in the trench. Also install "Y's" with caps or plugs every so often as clean-outs in case some rodent cares to make a home in it or you need to clean-out some blockage.
The whole set-up provides a very good drainage system. The cloth prevents sand/dirt/silt infiltration and clogging, the crushed stone provides a path for the water to get to the pipe to drain out or for the water to perc down if there is only a limited amount of water, and the clean-outs are easy to install when installing the system but much more difficult to do at a later time should you have a blockage in the future.
All materials are available at Home Depot, Lowe's, some plumbing supply houses and some masonry supply houses. There are also commercial fixtures available such as trench drains, drain grates, drain boxes, pop-up outlets, etc. available should you decide to incorporate that sort of thing in the system.
I did my first system over 40 years ago and it worked great. Have put several others in since then, using more machinery as it became available, and they all worked better than planned. Too old now to do them by hand so I just tell the younger ones how to do it, answer their questions and try to keep them out of trouble!
Good Luck, old slat
05/01/2011 2:54 PM
GA
Thats exactly what I did around my house 6 years ago, still works fine.
04/30/2011 1:12 AM
I hope you are not in the USA, because you are draining what would be classified as a wetland. The Corp of Engineers, the Bureau of Land Management, or EPA would probally shut you down, which I think is totally wrong.
Good Answers: 12
05/01/2011 7:25 PM
The city put a drain on the property, also a culvert in and out of the property. I am just directing the water to the drain (which doesn't work dependably). This is to keep another part from ponding. I am only talking about 2/3 of an acre. In some neighborhoods I would be in big doo doo. But not around here in central Illinois. Mosquitoes are part of the motivation.
Good Answers: 25
04/30/2011 7:33 AM
Hope this helps. jt. (nb. will not drain below natural water level.)
Dave asked his doctor if he had ever laughed at a patient.
"In over 20 years l haven't, l do my best to remain professional".
With that Dave dropped his trousers revealing the tiniest willy the Doctor had ever seen. It was no bigger than an AAA battery. Doc bursts out into uncontrollable laughter, wipes away his tears and says "I'm sorry, I really am, it won't happen again. Now how can l help you ?
Dave says "It's swollen"
Good Answers: 179
04/30/2011 9:54 AM
It appears to me from nearly 35 years experience as a Civil Engineer (one of my specialties is drainage & hydraulics) that a 4-inch diameter drain pipe is way too small, as there is a tendency for said pipe sizes to severely clog-up with mud, soils of all types and vegetation. You're going to end up with a throughout clogged pipe that's going to require a whole bunch of labor-intensive maintenance.
We don't know the overall contributing drainage area (no just the lot size), and hence the peak stormwater runoff (+ groundwater contribution) flow rate that will impact the drainage pipe in question. If it is not too great an area, then I would suggest no using a drainage pipe less then 12-inches in diameter so as to avoid the clogging issue as much as possible and to efficiently convey the ponded water from the lot to the nearby stream.
You could use either corrugated HDPE (with smooth interior barrel) or PVC (SDR-35) pipe. I would install it at a 1.0% gradient (1 foot drop in every 100 foot horizontal run) as a minimum. If use install the HDPE type drainage pipe then make sure you wrap the joints with a good filter fabric as others have suggested above.
One more thing: bevel cut the entrance end of the drainage pipe at a 45-degree angle to help limit hydraulic entrance losses, to help limit scouring/erosion action; it should conform to the ground slope. Absolutely place cobblestones under and around the entrance and exit of the pipe. You should also installed cobblestone pads before the entrance (at least 4' wide x 8' long) and the exit (at least 6' wide x 12' long). I find that using cobblestones around 6-inches minimum (smallest axis dimension) work fairly well, are easy to install by hand, and not prone to be washed away or dislodged readily when there's a small through moderate stormwater runoff flowrate.
Make sure your pipe trench is deep enough to prevent the pipe from becoming buoyant due to groundwater influences....I suggest that the depth of burial be a minimum of 2 feet atop the pipe, but if you're located in the northern states that experience deep frost penetration in the ground then use a minimum of 4 feet of soil cover atop the pipeline.
Good luck!
Good Answers: 181
04/30/2011 10:04 AM
You buy a house that some idiot built without adequate ground drainage, it's soon to hell with regulations.
The house built was on 2' of rubble fill footings in heavy clay.
I had to install drains on three sides of the house to stop flooding from three fields.
Drains were dug in to the clay 10' away from the footings.
I used 6" perforated pipe at a depth of 4'6" with ½" chatter as the base and above for about a foot. Above that and to within 6" of ground level, ¼ to 1½ crusher run.
It helped working in a quarry. The stone cost £0.20 a tonne. The digger a favour, the aggravation from the other half, eternity!
04/30/2011 12:17 PM
You've been given some fairly good advice here but I should add a few things. We get around a hundred inches of rain annually here where I live and I've been in civil construction all my life here so I do have a a fair working knowledge of what does and doesn't work for drain tiles. Smooth bore pipe is a necessity. The corrugated pipe traps silt. Dips in the pipe are a no no. Once again this traps silt. an 1//8 inch of fall to the foot will suffice if you carefully grade the pipe. Wye type clean outs placed a maximum of 75 feet apart will allow you to flush the pipe if necessary. Try to use 45 degree bends or less at angle angle points and install a clean out at the angle points. If you have much silt in your soils the filtration fabric around the pipe that people are suggesting will plug up. Screened rock around the pipe will divert most of it. A layer of non-woven filter fabric over the rock layer will work and would be easier to change out some day if necessary. And oh yes, 4" pipe will work if you follow all these guide lines but bigger is better if possible. The clean outs can be further apart if you up size but consider what you have available for flushing power. You may want to stick with the 75' guideline.
Good luck
PS I would use perf pipe and remember that the hole go on the bottom side, not the top as some would tell you.
Good Answers: 12
04/30/2011 9:23 PM
Thanks for all the great advice. My house is built well above the flood level, but the sump pump is on about a third of the time. I have a five foot crawl space on average. I have a cement perimeter and no wood touches water.
The question is actually about an extra lot that I bought. It is sort of saucer shaped, and I am just trying to get it to drain as quickly as possible. My house and my neighbors drain in to this half acre lot. The builders were going to put another lot on it, but gave up the idea. The soil is heavy clay, with silt on top.
I am just going to make " dry creeks" going to the main drain and culvert for the lot. Sometimes half of it "ponds" for up to a week. we get about 45 inches of rain a year. One of the dry creeks will be over a non perforated pipe that drains my neighbors sump pump. Mine goes into a "dry creek" that I dug, and enjoy watching flow into the extra lot.
Sorry I wasn't explicit enough in asking my question.
05/02/2011 7:31 AM
Most of your question has been answered but in future if you have questions you can always refer to the Ten State Standards. It is more for Wastewater Treatment but this section on Sewer Design might be helpful for minimum slopes etc...
I would agree with earlier posts that it is important to use geotextile cloth to prevent clogging, install clean-outs, if you use perforated pipe make sure the perforations are facing down, and avoid sags in the pipe as it may lead to clogging or odor if organic materials enter the pipe.
Good luck.
If you want to know what God thinks of money, just look at the people he gave it to. - Dorothy Parker
05/02/2011 10:26 AM
You didn't mention what kind of orchard. Tree type will dictate whether you really want to drain it or collect the rainwater in the topsoil for the trees to use.
Seems like the 'lot' needs some more clean, topsoil fill material to fill in the 'saucer'.
Easiest way to get it is to put a sign out front that says: 'Clean free topsoil wanted.'
Dig your creek first so that the standing water goes where you want it to.
Then, when you plant your trees, mound around the root base with the soil from the hole you have to dig so that rainwater flows around their mounds to the 'creek' instead of standing around their root systems which might cause root rot.
If you use a harrow or disc to break up the top one foot of topsoil, more of the rainwater will soak into the water table.
It will also allow nitrogen to permeate into the soil which your trees will need. What trees you plant and how deep their roots grow will dictate how closely you disc to the base of the trees and how much ground water you will be wanting to keep on-site.
Good Answers: 12
05/02/2011 11:03 PM
Good advice. The wettest spots will be a "botanical garden" of deer resistant water loving plants. River Birch, Bald Cypress, Redbud for trees, Astilbes, ferns, Day Lillies, Rose of Sharon etc. etc. The dryer, sunnier, areas will be for fruit trees with temporary screen guards. The area has White Pine on two sides, Silver Maples on one. Burr Oaks throughout the wet areas.
I replace most of the soil with planting mix when I plant the trees, Mixing some soil with the mix. I pick the highest spots on the lot.
I have always enjoyed directing water flows where I want it to go. Freudian?
05/03/2011 3:13 PM
You said:-
No, its what we men do every day (many times at my age!)......
Good Answers: 12
05/03/2011 11:34 PM
Likewise!
Register to Reply 21 comments
129CBRider (1); Andy Germany (2); Anonymous Poster (1); CaptMoosie (1); ChaoticIntellect (1); d_m_rosenberg (1); Garthh (1); jt (1); kramarat (1); old salt (1); ronwagn (7); Sourdough (1); TonyS (1); Tornado (1)
