Previous in Forum: DG Set Issues When Using a Diesel Generator   Next in Forum: Earthing System: Dirty/Clean Earth
Designing a 555-Timer for a Two-Way Alternating Signal
04/11/2007 7:35 AM
Hi friends- please think a duty like 5 AC (window) machine have to be operated for a duration of 2 hours contineously whereas other 5 machines to be kept non operating.After 2 hours the present sets of AC machines are to be stopped and other set of 5 AC machines to be in operation.So I thought of using a timer 555 which will change it's output polarity every after 2 hours once being connected or energised and will continue for days and months.If anybody can give a detail ideas of all the parts to be used and its designs etc then I will be very gratefull. Regards.
Re: Iwant to design a 555 timer to give timing signal in 2 way alternately.
04/11/2007 7:48 AM
Why build? - One can obtain timer devices over-the-counter that will do this when wired into the AC controls.
Good Answers: 18
Re: Designing a 555-Timer for a Two-Way Alternating Signal
04/11/2007 8:58 AM
Look up Omron H3C series of timers. They can be operated in "recycle" mode.
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
04/12/2007 9:11 AM
You can buy these over the counter, they will do anything you can imagine. They are fun to tinker with.
I used one to cycle a contol voltage to a charging motor to simulate 40 year life. The device worked perfectly 24 hours a day for two week. Always fired right on time.
I bought my stuff from NEWARK
“There's a sucker born every minute, and I happen to be one of them”
04/12/2007 1:05 PM
Friends-I know these are on sale over many counters - but technically to say I am on the way to do an experimental model using microcontroller,touch switch,LCD read outs and all the discreets will be cmos .The stored program will drive the timer. I request you to exchange some of your experiences .
Good Answers: 18
04/12/2007 1:39 PM
Well, use a 555 set up for a two-hour cycle and a flip-flop which changes state every two hours and make one set of 5 AC's run when Q output is high and make the other set of AC's run when Qnot is high.
04/13/2007 12:15 PM
Bill- it is a good starting.Well I can think of using a power supply of 5 volt.-InIndia,the supply is at 220 volt.So a step down transformer of 220/7 Volt and a max.5 VA capacity transformer is taken with 7805,capacitors etc as well as a battery to deliver 5 volt and also a charger are to be used.When I will use all these,the size will become a big .Can you think of any alternative to make the size as low as 200 cm 3 max.THANKS.
04/25/2007 1:54 PM
hi guys,
this is puneet.
can u plz tell me what are the alternatives to a 555 ic.
also what are the alternatives ic for 4017.
is there some site where i can get comparision of ic's whichperform some similar operation.
i need it badly.
thanks guys.
Register to Reply 7 comments
Anonymous Poster (1); bamunanka (2); Bill (2); PWSlack (1); T Man (1)
