Previous in Forum: Potential Servo Valve Problem?   Next in Forum: Preventive Maintenance and Inventory Management of IT 800xA ABB DCS
Flare Gas Meter Reading High
05/13/2011 7:24 AM
I'm using gf868 ultrasonic flowmeter of panametrics for flare gas flow measurement and recently observed that the flow in the morning remains 8000 kg/hr where as in the afternoon it increasing and went upto 120000 kg/hr where as from the process point of view there is no any flaring took place!
Observation is that temperature is increasing from 30 DegC to 46 DegC in this period and parallel Molecular weight also increased from 29 g/mol to 33 g/mol. Also whenever molecular weight fluctuates that time flow also fluctuates. Sound speed at high flow is showing 312 m/S .
So i would like to know that is these a cause of temperature? or molecular weight or effect of temperature on molecular weight and hence flow?
Pathfinder Tags: gf868 trouble shooting
Re: flare gas meter reading high
05/13/2011 7:41 AM
The speed of sound varies with both pressure and temperature, though a rise of 16degC is unlikely to be the whole cause of the apparent 50% increase in flow.
What does "time flow" mean?
Check the instrument's set-up and that the current parameters are the same as the as-commissioned parameters, in case someone has "fiddled" with it.
Re: Flare Gas Meter Reading High
05/13/2011 2:42 PM
dear i mean to say that
Also whenever molecular weight fluctuates that same time "flow" also fluctuates.
05/14/2011 10:29 AM
I don't know what gas you are talking about, but it is unlikely that the molecular weight to vary with temperature, if the chemical composition of gas remains the same
05/16/2011 4:36 AM
It seems that the problem is in the electronics of Flare Flow meter. Probably the flow meters must be installed in the field and due to heat of sun some component must be mall-functioning, this could be one of the reason of problem. With longer separation is possible (Sick - 1000m and Gf868 400+), nowadays people are installing electronics of flow meters at remote locations like control room or SRR. Other reason could be the Low flow, being intrusive (bias 90) sensors, they may not be able to see any flow during very low flow conditions. The cross duce measurement could be a great solutions for such applications. The Cross Duct sensors are also intrusive type but they inserted upto the pipe surface only and does measure the whole flow profile. Solutions are available from two company one indeed Panameterics and other is Sick Maihak Gmbh. Try out...
Register to Reply 4 comments
Anonymous Poster (1); jerybaciu (1); PWSlack (1); tapasvi (1)
