Previous in Forum: Wye-Delta Transformer in Power System   Next in Forum: Notifier Fire Alarm Panel Affected by Lightning
11 comments
India - Member - New Member
Fuse Wire on HT Side
05/13/2011 11:30 AM
Dear CR4 users
I have a small doubt
I have 20A fuse wire which we are using in LT section can we use this same fuse wire in HT side in same rating. If we can't please give me formula or ratio of current difference
key questions why, what & how - just think
Good Answers: 164
Re: Fuse Wire on HT Side
05/13/2011 12:20 PM
Please !!!
You are using fuse WIRE ? Not HRC fuses ? Gawd help us !
i give up.
i tried to give you some help via pm on CR4, but i must admit, you are beyond my help. Sorry.
Good Answers: 181
05/14/2011 1:33 AM
You have a small doubt?
I have a major one as to the sanity of our OP!
You can't use fuse wire in HV gear!
Good Answers: 170
05/15/2011 10:18 AM
Planning to celebrate Diwali soon in your plant?
05/15/2011 4:03 PM
Words cannot describe how dangerous and illegal it is to use fuse wire on a high voltage system (apart from the fact it likely won't break the circuit without a massive arc).
Actually they can, consult your electrical codes and regulations which will clearly state this (no matter what country you are in).
Please get someone more qualified to size, purchase and install the appropriate HRC fuse designed for the voltage and fault rating of your system. This will prevent injury, death, legal/criminal issues against the installer (or all of the above).
05/16/2011 4:26 AM
it is 11kv line in India that too in Andhra it is quite usual even Transco department people use fuse wires in HT side at consumer end
OK you people are right present i can't replace fuse wire with HRC or circuit breaker or some other
please give me explanation for this question
If a conductor is carrying 40A of current in LT side con we use the same conductor for carrying 40A in HT side
05/16/2011 4:50 AM
Please engage an appropriately-qualified Electrical Engineering consultant locally before someone gets hurt/killed.
05/17/2011 2:57 PM
That doesn't make it right, safe or even necessarly legal (what do your your local standards have to say regarding this).
Try harder, HT HRC fuses are cheap and easily available. As someone who works in the power transmission and distribution industry to Australasian, European and American power standards HRC fuses are your cheapest alternative. Fuse wire alone is just not safe, will not fail safely, may not even break the circuit correctly in the event of a high fault current and forget about time/current fuse grading and protection discrimination.
If a conductor is carrying 40A of current in LT side con we use the same conductor for carrying 40A in HT side.
No you cannot use the same 40A fuse wire on the HT side.
Any Electrical engineers here familiar with the Indian electrical standards that can offer comment.
Good Answers: 181
05/17/2011 3:07 AM
Do you want the conductor size or fuse size?
Good Answers: 164
05/17/2011 5:07 AM
Doesn't matter. The conductor will act as the fuse. Haven't you seen a $400 TV tube blow to protect a 10¢ fuse?
01/13/2013 11:28 AM
Dear Mr.parvathaneni,
The answer for your question is YES. We can use the same fuse for H.T side also.
DHAYANANDHAN.S
01/21/2013 12:58 PM
Did you carefully read the original question before posting this incorrect and dangerous answer or are you trying to get someone killed.
Register to Reply 11 comments
dhayanandhan (1); electricalexpert65 (1); jack of all trades (3); kvsridhar (2); parvathaneni (1); PWSlack (1); TonyS (2)
