Previous in Forum: Online UPS Design   Next in Forum: Requirements of 12 Volt DC Motor
10 comments
VCB Tripping
05/15/2011 2:35 PM
The VCB in my firm is tripping at full load due to earth fault. This happens at full load after 5 minutes or so.Could any one throw some light on this issue
Thanks in advance.
Good Answers: 181
Re: VCB tripping
05/15/2011 4:38 PM
I can lend you a torch!
You need to give more information.
Re: VCB Tripping
05/15/2011 11:54 PM
Can you give me the info related to make of VCB.
India - Member - New Member
Good Answers: 164
Re: VCB Tripping
05/16/2011 12:21 AM
Since it happens after 5 minutes of full-load running, some thermal phenomenon is indicated....to wit, some conductor's insulation is developing a leakage to earth, after getting heated a bit. You can perhaps trace that weak point by meggering.
Good Answers: 19
Re: VCB Tripping
05/16/2011 4:27 AM
Please furnish the following information to help you. Relay make and type. CT ratio. Relay settings. Load current. What was the current when VCB tripped
Ramesh,Freelance Electrical/automation Consultant
Re: VCB Tripping
05/16/2011 6:48 AM
What's the rating of the VCB? The Earth fault relay is residually connected? If so, in full load condition, if there is substantially amount of unbalance current, zero sequence component of unbalance current may flow thru the earth fault relay and may cause tripping.
Manindra
Good Answers: 164
Re: VCB Tripping
05/16/2011 9:13 AM
Dear manindra,
i have a small doubt here. In all systems i have seen in LV, all four cables (3P+N) pass through the core-balance CT (CBCT) which vectorially sums up all the currents, including any unbalance currents. The relay will not trip for any unbalance, only for any current flowing outside the CBCT, which can only be an earth leakage/fault. What you are saying here is different...maybe things are different in MV/HV ? Not that i think so....
Re: VCB Tripping
05/16/2011 9:34 AM
Dear kvsridhar,
What you have told in case of CBCT is absolutely true. I have indicated that in case of Earth fault relay is residually connected in the CT secondary circuits, in case of high line unbalance currents, zero sequence component of unbalance current may flow thru E/F element and if that amount exceeds threshold value(pick-up value) E/F relay may operate.
Manindra
Good Answers: 164
Re: VCB Tripping
05/16/2011 9:43 AM
Ah, ok. i think i get it. Thanks.
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
Re: VCB Tripping
05/16/2011 9:50 PM
Additional to manindra:
1. What is the parameter shown at the point where the trip occurs?
2. What is the setting range?
3. What is the type of earthing protection scheme?
4. What is full load current?
Anything that can go wrong, will go wrong
Re: VCB Tripping
05/16/2011 8:51 AM
What's so difficult about eliminating the earth fault that is causing the trip?
Register to Reply 10 comments
hien.nguyenquoc (1); kvsridhar (3); manindra (2); NUKALA (1); PWSlack (1); ramvinod (1); TonyS (1)
