Previous in Forum: Reverse Mounting Arrangement For Proximity Probe   Next in Forum: Tubing
Full Bore vs. Reduced Bore Ball valve
05/16/2011 7:10 AM
What is the selection basis of Full bore and Reduced bore ball valve?
Pathfinder Tags: ball valve Full Bore Reduced Bore
Good Answers: 18
Re: Full Bore vs. Reduced Bore Ball valve
05/16/2011 7:55 AM
Hi Metla.ani
From my experience of selling them, it is cost, as they are usually cheaper to buy but it is important to check if the reduced bore valve will pass enough flow for the application.
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
05/16/2011 10:37 AM
Also, if the line will be pigged, full-bore valves are required.
Good Answers: 18
05/16/2011 11:11 AM
Hi Tornado,
A GA from me. I forget how diverse a site this is, pigging lines is not something I have had anything to do with in my 40 years of selling, it depends on the industries you deal with.
Best regards,
John
05/16/2011 4:42 PM
Another condition requiring full-bore valves is horizontal or slightly graded lines that need to be fully drained through the valve (otherwise a puddle forms).
05/17/2011 7:09 PM
A couple of places we had to use them - 1. In a service such as coatings or paint processing where, if the lines were drained and a valve was left open, the paint or coating could dry on the ball and that valve will never close again (similar problem that was mentioned above), and; 2. In dense phase solid transport where the exposed ball with get eroded severely by the entrained solids. In both cases we will normally specify full cavity fillers around the ball. Those fillers lead to another issue that needs to be overcome - larger required operating torque on the valve.
06/09/2011 5:08 AM
Many a times it depends upon the extent of shutoff required. Reduced bore ball valves provide more tight shut-off than full bore ball valves(useful in flammable atmospheres). This is particularly suitable for multiple port ball valves.
Register to Reply 6 comments
ameysdhaygude (1); jesw55 (2); JSCadman (1); Tornado (2)
