Previous in Forum: About The API Thread Size   Next in Forum: Condensate Drain Piping Of Fan Coil Units
10 comments
Fire Dampers
05/22/2011 11:36 AM
Some small ducts (6 x 6 inches) going through fire rated walls in our building have been provided with Fire Dampers but without Access Doors. Is it a must to provide access doors for each fire damper regardless of its small size?
Re: Fire Dampers
05/22/2011 12:03 PM
Do you suspect that the building was not built to code, or just curious?
Re: Fire Dampers
05/22/2011 3:12 PM
The fact that there are fire dampers indicates that the codes are certainly involved. The argument being advanced against providing access doors in very small ducts is that the small access would not allow the two hands to go inside to manipulate the fusible link of the curtain type damper, so what's the function of providing one.
Thanks
Re: Fire Dampers
05/27/2011 9:26 PM
It is not practical to have Access doors in such small ducts for the above reasons, though code requires access doors where Fire dampers are required.
rkumar@dsny.nyc.gov
Re: Fire Dampers
05/29/2011 9:04 AM
This would leave one in the lurch as your response is yes and no at the same time. A definite verdict is what is required, whether access doors must be installed even though, functionally speaking, one would not have any physical maneuvarability due to their size other than being able to know visually whether it was open or shut. Another question that stems from the first question is that once the damper was installed in the open position and the fusible link was intact, is there any possibility or event that would release the link besides a fire??
Re: Fire Dampers
05/22/2011 6:19 PM
You need to check the code for access requirements or contact the fire marshal.
Mr.Ron from South Ms.
Re: Fire Dampers
05/22/2011 10:59 PM
Still waiting for an informed opinion about the requirement of the codes (not just city or local codes) in the matter of Access Doors for very small duct sizes
Re: Fire Dampers
05/22/2011 11:22 PM
Per the International Mechanical Code, section 607.4 and the International Building Code, section 716.4 all fire dampers installed are required to have access panels installed, clearly labled "FIRE DAMPER" OR "SMOKE DAMPER".
Re: Fire Dampers
05/23/2011 10:06 AM
If it moves, it needs to be accessible.
Re: Fire Dampers
05/24/2011 3:11 PM
I am with you on this one from head to toe, but the arguments being advanced against it are that the teeny weeny access door would not allow the fusible link to be relatched, so what's the point?
My argument has been that the access door would at least allow access to our vision about the open or close status of the damper
Re: Fire Dampers
05/23/2011 11:57 AM
Absolutely! Lou Bindner
Register to Reply 10 comments
786verycool (4); Fredski (1); johnsonr1 (1); Lou Bindner (1); lyn (1); ronseto (1); thakral1 (1)
You might be interested in: Interior Doors, Dampers and Louvers, Exterior Doors
