Previous in Forum: Designing a Power Supply for MIL-STD-704A   Next in Forum: Computer Engineering Help Needed: Eliminating Illegal Electric Connection
8 comments
Semiconductor Diode Component Needed
04/12/2007 8:51 AM
I have a requirement for a device that essentialy is a pair of back-to-back power silicon diodes in one package, with a current capacity of +or-10 Amps and a PIV of a 2 Volts max. Yea- 2 Volts Thats all, but must be an isolated package with the possibility for efficient heat sinking and be as small in dimentions as possible-Any Ideas?
INDI-LINK makes 'Light' of 'Current' events, a veritable window into wiring.
Re: Semiconductor Diode Component Needed
04/12/2007 2:54 PM
I have searched high and low but can not find a parts to match your requirements.
The PIV is the stumbling block Why do you need such a part? Can another part be used? Knowing the application would help. I source parts all day and night.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Good Answers: 42
04/12/2007 11:15 PM
Forward drop is at least 0.7 volts. 10 Amps will dissipate 7 watts at .7 volts, or 10 watts at 1 volt. This is not a small device and will need a heat sink.
Now about that 2 volts, so what if it is 50 volts or 100?
Are your diodes in anti-parallel or back to back series? 2 terminal device or 3?
Details please.
Try MBRF1045 in an isolated TO-221E, Schottky Rectifier.
04/13/2007 5:41 AM
When you specify a PIV of 2V max: are you saying you want it to break down if the reverse voltage is greater than 2V, or are you just saying that you hoped you could get a part which meets your other requirements in a smaller package if you really relaxed the PIV spec.
Why do you especially want a single package?
When you say back to back, do you mean common anode? 3 pin package?
04/13/2007 11:15 AM
I read the question as being he wants a package with 2 diodes back to back, which to me means they are in parallel and reversed polarity, so the peak forward voltage will always be 1 volt or less as one or the other diode will be conducting..??
Unless he means in series connection, then he would need 2 2 volt zeners to give his PIV of 2 volts???
Strange whatever....
John.
04/13/2007 12:07 PM
My double diode, back to back device is required to act as a resistor of negative resistance that develops a fractional voltage across it of 1.2 Volt Max. I believe the PIV rating of a diode is proportional to the thickness of silicon used in their manufacture. As size is important I need this thickness to be minimal.
At present I am using a diode bridge with AC and DC terminals shorted out to form such a component albeit with double diodes but I suppose this give some redundancy to any failure of one set. PIV is not imortant as you say.
04/13/2007 12:43 PM
Good Answers: 42
04/15/2007 12:54 PM
If that is a continuous 10 amps (not pulsed) you will need a significant heak sink. How are you planning on doing that? The heat sink will be much larger than the diodes.
04/17/2007 11:20 PM
you can find it from net, for example irf has wonderful such large power diode pair for selling.
Register to Reply 8 comments
BrainWave (1); cnpower (1); docrobgar (1); Electroman (1); GW (2); Randall (2)
You might be interested in: IC Package Converters and Adapters, Back-up Rings
