Previous in Forum: DG Syncronisation   Next in Forum: Presentation On LT POWER SYSTEM
15 comments
Compressor in Air Conditioning System
06/03/2011 4:47 AM
What is the difference between compressor in air conditioning system and that using where air pressure is required. Shall we change an ordinary compressor to A/C one?
Re: compressor
06/03/2011 4:58 AM
Not advisable.
Re: compressor
06/03/2011 5:00 AM
Given that the fluid being compressed in an air conditioning system is one with different properties to air, it would seem highly inadvisable at first sight.
What "we" do is indeterminate at this time, as the reason for doing it is as abstruse as it is obscured.
Good Answers: 88
Re: compressor
06/03/2011 5:10 AM
Even if you solved all other problems you need an environmentally sealed compressor. Air compressors generally are not (because they don't have to be). S.M.
Good Answers: 445
Re: Compressor in Air Conditioning System
06/03/2011 12:28 PM
On the back of a napkin, no problem, they both compress a gas to a higher pressure. In reality, the gases have different properties, you really don't care if there are small air leaks since you have an infinite supply of air, but not so if the working fluid is a refrigerant. However, if your question was reversed, then the answer is "yes, you can use an a/c compressor as an air compressor (or vacuum pump for that matter)".
Good Answers: 80
06/03/2011 10:52 PM
You are correct. We used one on the farm for many years. As long as there is oil in it and that it doesn't suck in too much dust it will work OK.
Make sure that you have an over pressure valve and a pressure switch to stop it.
Most AC compressors are relatively slow but are very quiet.
They are not very good when starting under pressure. We usually had to get the pressure below 40psi before the compressor could start without tripping the overload.
Don't forget that compressed air is dangerous. Tanks explode like a bomb. Use over pressure protections.
Good Answers: 266
06/03/2011 3:04 PM
Isn't it all ready conditioning the air, changing the pressure.
Good Answers: 48
06/03/2011 7:05 PM
I would say an A/C compressor is just as ordinary, if not more so, than your 'ordinary compressor'. In fact, there are very many different types of compressor (screw, scroll, centrifugal, piston, etc.) all designed for very different applications and fluids. It's the same with pumps, and you wouldn't want to be switching water, oil, fuel and washer pumps in your car. They are all pumps, but quite different.
'What is the difference...?' Too much to expound here. Try this, http://en.wikipedia.org/wiki/Gas_compressor , for a start.
06/04/2011 12:38 AM
Please Do not use an a/c compressor as an air compressor !!!!
I have advised that for 45 years and still people go right on and do what they wanted to do before they asked even when I try to explain that the clearance between the pistons and the head are in the two to three thousands range and an a/c compressor allows 4% of crankcase capacity to pass by the pistons and rings so when you allow air to enter an a/c compressor you can develop the same air/fuel ratio as a diesel and guess what you have an explosion and if it continues on into the crankcase it can be life threatening
I think the only reason some have got by doing that is that they used worn a/c compressors that could no longer develop pressures in the diesel range and I'm sure they also got by with using throwaway refrigerant tanks for air bubbles before they put one way hand valves on the tanks
A top notch compressor salesman called on me many years and he walked with a bad limp and after many years I finally had to ask about his leg
He said he had a 50 hp belt drive a/c compressor blow up and a piston and rod hit his leg I asked why it blew up and he said he was ashamed to tell me but finally admitted that he allowed air to enter the compressor and it dieseled and blew the rod and piston out through the crankcase wall
Maybe there are more in this forum that can share a story about the loss of a limb or a friends life that can convince you to buy and air compressor instead but then again maybe someone can convince me that all the people that warned me were wrong
06/04/2011 10:30 AM
I think OP suggested the reverse scenario. Air compressor converted to A/C. S.M.
06/05/2011 12:13 AM
I'm sorry this old man accidentally jumped up on the pedestal and started preaching against using a/c compressors for air service
I didn't understand the exact question posted and there may have been a little language
barrier between two posters from different countries for which I apologize but then again if I accidentally convinced one person not to do that it was not waisted time
06/04/2011 4:48 AM
Equipment designed for particular application should be used for that application only. It is a good professional practice. In air craft refrigeration air is bled from the compressor of the jet or gas turbine engine or is supplied from an auxiliary compressor source and cooled in an air heat exchanger . It uses reverse Brayton or Joule or Bell Coleman cycle.
06/04/2011 9:14 AM
The "difference" is using one is the correct thing to do, using the other is Mickey Mouse.
Good Answers: 19
06/04/2011 7:25 PM
NO!!!!
That would be like I saw an air station storage tank being used as a Expansion Tank in China Town in San Francisco. As Tornado said "Not recommended".
06/05/2011 1:36 PM
Let's compare compressors
Air comp - open crankcase allows blow-by to vent to atmosphere
A/C comp - sealed crankcase blow-by must be re-compressed
Air comp and oil - designed to prevent rusting of components when exposed to air
A/C comp and oil - instant case of rust when exposed to air sometimes in minutes and chemical changes in the oil when contaminated with moisture
Air comp - designed for heat dissipation with fins, inter-coolers and forced air flows
A/C comp - designed to be cooled internally with 40 to 60 degree flow of returning suction gases and sometimes external fins with forced air flows are also required
Air comp - many require cylinder unloading for starting which vents to atmosphere
A/C comp - many must start against head pressure or off cycle equalization
The only thing these compressors have in common is that they both compress gases but the completely different methods of internal heat removal, crankcase sealing, metal compounds, rubber seals, compression ratios and oil etc do not allow swapping their application
It won't fly Newt
We must be very careful as any change in application also removes you from a mfg's insurance umbrella and makes you the mfg with all the related legal responsibilities
06/06/2011 11:13 AM
NO period!
Register to Reply 15 comments
Anonymous Poster (1); Fredski (1); Holzfeller (1); jgroberson (3); Lou Bindner (1); marcot (1); mrswamy (1); ozzb (1); PWSlack (1); RAMConsult (1); SimpleMind (1); Stedou73ish (1); Tornado (1)
You might be interested in: Compressor Repair Services, Air Handlers, Air Valves
