Previous in Forum: Surface Crack Internal Crack in En19 Shaft (18 mm dia)   Next in Forum: Rosin Resistant Control Panel Labels
Figuring Gas Line Pressure
06/04/2011 9:05 AM
How do I figure the proper gas pressure for 1/2inch gas line being used for a fireplace in our home?
Pathfinder Tags: gas pressure
Good Answers: 444
Re: Figuring Gas Line Pressure
06/04/2011 1:29 PM
You don't, it is always specified in the installation instructions that come with the gas appliance. Of more importance is the material(s) used in the piping, everything must be compatible with the type of gas and the local codes.
06/04/2011 6:11 PM
Toward the end of this article it mentions 1/4 psi (~7" water column) pressure; I've also seen 10" w.c., but local Codes might vary. Be sure to check those, because they will govern the allowable pressures in various types and locations of pipe/tube/hose.
06/06/2011 3:57 AM
Get a registered professional to install it, particularly if the home's fire insurance policy is worth the premium.
Register to Reply 3 comments
PWSlack (1); RAMConsult (1); Tornado (1)
