Previous in Forum: Figuring Gas Line Pressure   Next in Forum: Anodizing AA380
8 comments
Rosin Resistant Control Panel Labels
06/04/2011 10:17 AM
im having a very hard time locating any information on labels that are sap/rosin resistant or proof. the sawmill i work at recently gave me the head elect. position and i really wanna get these panels where anyone can read them and or operate them. anyways if anyone can help me out it would be very much welcomed.
MattJohnson
Re: Rosin Resistant Control Panel Labels
06/04/2011 11:24 AM
06/04/2011 12:26 PM
This is simply a question of solvent resistance.
Turpentine - Wikipedia, the free encyclopedia
Good Answers: 70
06/05/2011 12:09 AM
Have you thought about using an electric pencil for engraving you panels? Engraving metal or plastic tags and attach the tags with either epoxy or RTV? RTV would be easy to remove if you need to relabel the panels. DJ
06/05/2011 11:47 AM
Oh, I can't believe I didn't remember engraved lamacoid tags, black lettering on a white or light background.
06/05/2011 12:19 PM
All have good suggestions and I think ill do a combo of all. Engrave plexi glass and bolt labels to panel and clean them with alcohol or some turpentine like solvent. So maybe the sap will get trapped on the engraved area and make the label more visual.. what ya think
MattJohnson
Good Answers: 70
06/05/2011 1:13 PM
Hi Mat, I thought about mentioning nuts and bolts for attaching the tags, that would entail removing the interior panel and a lot of drilling. And being your in a saw mill, I'm sure you have a lot of sub panels though out the mill. Then you also have the problem securing the outer panel cover so no fool would stick they're hand in it while your drilling and fastening the tags. That's why I suggested using RTV. The epoxy would be fine except is more permanent solution for attaching the tags. DJ
06/05/2011 2:49 PM
I understand your concern. I do have a nightshift electrican who could do it while we were down. He's more of a transmission line guy than a controls/industrail elec. anyways.
MattJohnson
Good Answers: 70
06/05/2011 3:31 PM
Good Luck in your new position and fun, Dan
Register to Reply 8 comments
dj95401 (3); lyn (1); MattJohnson (2); rhkramer (1); Usbport (1)
You might be interested in: Label and Nameplate Services, Composite Panels
