Previous in Forum: MCB for AC and DC   Next in Forum: Conduit Fills
10 comments
kva
06/09/2011 10:44 AM
Hi All,
How do you calculate the transformer primary and secondary for kva?
Can i calculate kva for Direct current " DC "
Regards
Anonymous Poster #2
Re: kva
06/09/2011 10:50 AM
You'd better calculate Kcal for that on the primary. S.M.
Anonymous Poster #3
Re: kva
06/09/2011 11:02 AM
What? (Volts)*(Amps)/1000
Good Answers: 140
Re: kva
06/09/2011 11:14 AM
KVA is a component of an AC system and does not exist on a DC system. So you can not calculate it. For DC systems, straight kilo watts applies.
Re: kva
06/09/2011 11:17 AM
I think you need to clarify your question. Are you trying to design a transformer or buy one?
Generally, to buy (or design) a transformer, you first need to determine the voltage on the primary and secondary, and then also determine whether you need single phase or 3 phase power. (If three phase, you will need to consider whether each side should be delta or wye connected. This depends on things like the grounding scheme you plan to use.)
Then you need to look at the loads you need to serve (considering an allowance for future expansion and such). That determines the kva. If your load is too big, you may need to divide it and serve it with multiple transformers.
The designers of a transformer design the wire size, core, and such, to handle approximately kva on the primary and the secondary.
For DC, you can calculate KW, which is essentially the same as kva for DC as the power factor for DC is 1.
Re: kva
06/09/2011 11:44 AM
Hi all, I have bought my own transformer 240vac 24-0-24vdc for my own use, and wanted to install mcb for protection on both pri. & sec. Please advise.
Re: kva
06/09/2011 12:10 PM
How many kva (or amps, on the secondary)?
Anonymous Poster #4
Re: kva
06/09/2011 1:14 PM
Too many kvas
Re: kva
06/09/2011 2:10 PM
what is the rated secondary current of the transformer ?
Re: kva
06/16/2011 7:46 AM
The protection is needed to protect the wiring, not the transformer!
Anonymous Poster #5
Re: kva
06/16/2011 9:05 AM
Transformer 240vac 24-0-24vdc
Anonymous Poster (5); North of 60 (1); pravinba (1); PWSlack (1); rhkramer (2)
