Previous in Forum: PF Fineness Problem   Next in Forum: Steam Engine
18 comments
United States - Member - Proud to be a part of this Great Nation
Need to Match 2.375-Inch Diameter Shaft to Split Base Type Pillow Block Mounting
06/14/2011 5:18 PM
I have a 2.375 diameter steel shaft and need to mate a split base type of pillow block bearing mount. The bearings can be standard or ball bearing. There is a minimal load on the shaft, basically will use the shaft as a sort of 'see-saw' mechanism to perform some testing. I've noted that some manufacturers have close offerings to the dimension I need of 2.375. Several manufacturers had 2.360-inches in diameter or 2.438-inch diameter, etc., but couldn't find one for exactly 2.375-inches diameter. Is it possible to take up some of the dimensional variance some way when purchasing a slightly larger diameter bearing (i.e. using a 2.438-inch diameter for the 2.375-inch diameter). Also, I would like to utilize a split base type of pillow block to ease the installation. Thanks!
~Research Is Something I Do When I Don't Know What I'm Doing~ Wernher Von Braun
Re: Need to Match 2.375-Inch Diameter Shaft to Split Base Type Pillow Block Mounting
06/14/2011 5:35 PM
Depending on several factors, maybe you can cool/freeze the shaft and heat the 2.36 inch ID bearing with a tourch. That'd give you a nice tight fit when things go back to room temp.
Next simplest, a bushing to go over the shaft with a 2.48 finished OD.
06/14/2011 5:55 PM
You could put a (possibly shrink fit) sleeve over the shaft, but I think you'd need a bigger bearing--I don't think a sleeve of 0.039" thickness would be practical.
Or, yo"flame spray", then turn it down to 2.438"--I think that would be more practical.
06/14/2011 8:03 PM
Hmm, something got mangled there--it was supposed to say: Or, you could build up the shaft with weld or "flame spray", then ..."
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
06/14/2011 6:40 PM
There are a couple options I can see, rhkramer already mentioned one that I think is your best option, have a shaft sleeve machined.
Another would be to locate a vendor that carries a bearing to fit your situation. (I haven't purchased bearings in a few years, but SDF has huge product line and they've performed well for me.)
The last would be to simply scrap the pillow and buy a new bearing and block (and take note of which one it is so you can buy replacement bearings in the future).
I wouldn't recommend trying to shim any type of moving part.
Sometimes my thoughts are in a degree of order so high even I don't get it...
06/14/2011 9:43 PM
For this seesaw type action (as opposed to continuous rotation), 0.039 of shim stock should be okay. Another option would be to turn your shaft down to 2.360-.
06/15/2011 9:53 AM
I think I'll try to use your idea Tornado. Although this is going to be a testing apparatus, it will not see a lot of use, nor does it have high rotational stress on it. I like the latin signature. The first part was made a little famous in the movie Tombstone, where Doc Holliday says: In vino veritas, very true! thank you
Mach1GTX
Good Answers: 123
06/14/2011 10:02 PM
I would think that a bushing would be an easy cure. But I would recommend going to 2.5" or bigger on the bearing.That would make the bushing more substantial, and would allow set screws to anchor it to your shaft. Good luck.
Bob
Good Answers: 181
06/15/2011 3:47 AM
Have you considered a taper sleeve bearing? They can accommodate slight over/under size shafts.
06/15/2011 9:57 AM
I'm not familiar with bearings much at all and am just now getting into them. What I have to do is not my favourite thing, but part of this test rig I'm putting together. Does a tapered sleeve bearing cause undue wear on the bearing or mating surfaces?
Good Answers: 181
06/15/2011 2:43 PM
No, once the taper sleeve is locked in place the bearing takes all the stress. They will accommodate slight shaft size variance. I like them, simple to fit, easy to remove, what more could you want?
06/15/2011 3:00 PM
..............well, uh, I was hoping you could send me the setup? Just kidding, thanks Tony! How are things across the pond?
Good Answers: 181
06/16/2011 9:38 AM
WET! A typical English summer where I live.
Good Answers: 196
06/15/2011 11:23 PM
This may be too far outside your comfort zone or just plain inconvenient where you are located; but look into replacement main bearing inserts for early overhead v-8 engine. Note that these things come in undersizes.
Another possibility is to run down a shop that does antique car engine rebuilding and see if they can pour and bore some babbitt bearings for you to fit your shaft. These guys that do this sort of thing are usually set up to do that specific job and don't have the overhead costs of a regular jobbbing machine shop. A cast iron pillow block designed for a 65 or 70mm OD ball bearing would be perfect for the babbit job. Just discard the ball bearing that comes with it and have them replace it with babbitt machined and/or scraped to fit your shaft. Basically the same thing they do when they repour and fit the crankshaft main bearings in a Model T or A Ford 4 cylinder block.
Ed Weldon
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
06/16/2011 12:23 AM
Someone mentioned SDF bearings. I think they meant SKF bearings. I would call SKF, or Timken Bearings, or FAG Bearings, and get ahold of an applications engineer, and just explain to them what you explained to us. What they will most likely suggest to you is to use a tapered sleeve bearing, as TonyS suggested. I don't believe you will find one of those in a split sleeve type block, but unless you absolutely need a split block, this is the way to go. A tapered sleeve has axial cuts around the diameter. When the outer sleeve is tightened onto the inner tapered sleeve, the cuts allow it to tighten up on the shaft, the more you tighten it. They generally have a range of movement that will allow for considerably undersized shafts.
This would be much easier than building up the shaft or machining it down (unless of course, you have quick and easy access to a lathe and machinist)
06/16/2011 1:35 PM
mach1qtx, depending on shaft RPM & loading, you made able to simply use a tolerance ring. Here is the website for USA Tolerance Rings www.usatolerancerings.com . Paul
Good Answers: 110
06/16/2011 2:09 PM
Interesting that imperial sizes have become a little more difficult to find, but yes, that is exactly the way to go.
Think big. Drive small.
06/16/2011 4:31 PM
Wow--good catch! I was sitting sort of scratching my head and wondering why it was so hard to find a 2 3/8" bearing!
09/10/2011 8:46 PM
if the use is just a rocking motion, which by the way is the severest motion for wear, and it is very light duty, you could also do without the bearing. Just get an oil impregnated bronze bushing that has the right diameter. press it into a drilled hole in the right place. it actually needs to be a press fit. then bore the bushing to the proper dia. if you want the shaft horiziontal and just a few inches of the working surface, then make a T block or an L block. drill holes in it for mounting down to the working surface and the press fit hole for the bushing. the press fit will decrease the diameter of the id.
that is why it will need to be bored. always. this is for a non high speed operation. the bushing should last many years.
Register to Reply 18 comments
artbyjoe (1); bob c (1); ChaoticIntellect (1); Ed Weldon (1); K_Fry (1); lyn (1); mach1gtx (3); Out of Box Experience (1); Paul Morgan (1); rhkramer (3); TonyS (3); Tornado (1)
