Previous in Forum: Combustion of Woodparticles   Next in Forum: Lunar eclipse 15th June 2011!
8 comments
Needs to Find Ways to Reduce Running Costs
06/15/2011 3:29 AM
Can anyone guide me about new technologies with which we can reduce running costs, increase efficiencies in HVAC systems...
I know one like using EC Fans instead of standard belt driven fans...
Re: Needs to find ways to reduce running costs
06/15/2011 3:54 AM
Turning it off when it is not needed is a good one.
06/15/2011 4:02 AM
I don't know what an "EC" fan is vs. some other kind.
Turning up the thermostat a little can help.
Somewhat less practical would be to increase the surface area of the evaporator and/or condenser.
If this is a fairly large unit, there may be a way to change to an evaporative vs. air-cooled condenser.
Be sure that your existing evaporator and condenser are clean, and any bent fins "combed" out.
06/15/2011 4:23 AM
can we increase surface area with some nano paint?
First do it and then talk about it
06/15/2011 4:40 AM
??? Probably not.
Re: Needs to Find Ways to Reduce Running Costs
06/15/2011 8:49 AM
The obvious answer(s) is to either stop running.....or buy less expensive running shoes.
J B
06/15/2011 11:18 AM
You need to define your situation quite a bit better if you want some quality ideas.
Good Answers: 54
06/16/2011 12:05 AM
Insulate, seal off all drafts, only heat/cool where you need to, alter the thermostat settings, reuse waste heat from other areas.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
06/16/2011 7:07 AM
Use latest control system like BMS and set the optimum parameters. Carry out routine maintenance regularly as per the schedule.
ffej (1); Fredski (1); JBTardis (1); keyur_197 (1); mrswamy (1); PWSlack (1); Tornado (2)
