Previous in Forum: metering instrument parameters   Next in Forum: Rated Operating Sequence
10 comments
Cable Voltage Drop Calculation
06/15/2011 11:19 AM
As experts and designers knows that, in cable voltage drop calculation we consider only real part of complete equation i.e. ( I.R.cos (fi) +I.X.sin (fi) ). we are assuming imaginary part of this equation as negligible hence not to consider. Pl. note due to addition of this imaginary part cable size for standard run lengths say 250 mtr. increases. In my openion, in comparison with conventional formula and it's application as standard practice in industry, this new complete equation un-necessarily increases cable size in turn cable cost...moreover wastage of national resources, probably. Whether, it is feasible and techno- commercially right practice to consider complete equation with its imaginary part also? When to use and when not to use this imaginary part?
Engineering is an APPLICATION..
Pathfinder Tags: Cable voltage drop
Re: Cable Voltage Drop Calculation
06/15/2011 11:23 AM
British Standard 7671.
06/15/2011 10:56 PM
The angle in question is usually denoted by the Greek letter phi (φ). Depending on your browser, the composing window for CR4 posts includes a special symbol menu, shown by Ω in the tool bar. Selecting this menu allows you to insert such symbols as ©, ≥, ÷, √, →, ¿, and other useful items. Similarly, the x2 and x2 features allow you to insert subscripts (e.g., H2O), and superscripts (e.g., πr2).
06/15/2011 11:13 PM
My friend! Thanks for your reply but unfortunately this is not answer to my main question. Requested to involve if someone knows correct answer. Pl. note I stated this discussion only for knowledegous elect. Engineers for their expert sharings and not for MS world format editors or English teachers who will just increase their number of posts in forum!!
06/15/2011 11:50 PM
Welcome aboard. Surely you will enjoy yourself here.
Good Answers: 140
06/16/2011 12:04 AM
Geese Tornado... I guess you were told. Some people's kids!
06/16/2011 12:48 AM
Somehow I thought the OP's formula was supposed to have an imaginary part. Too bad I am not a "knowledegous" EE, but as a mere "English teacher" I hazard this guess:
IR cosφ + iIX sinφ.
I haven't yet seen a Code that uses this formula for computing voltage drop, however.
06/16/2011 2:16 AM
As long as the comsumer gets the voltage within the 10% range you can calculate the voltage drop as you wish. Try both ways and see which one gets the lowest value. Use that one for dimensioning the cable.
The time is ......now
Good Answers: 181
06/16/2011 4:28 AM
Salunkhem, if you can't take the banter that goes on between engineers I would suggest you close the door behind you when you leave.
06/16/2011 8:43 AM
I am not a cable designer, only humble EE. But I don't think the formulae that you gave is correct.
V = IRCosφ + IX Sinφ
The voltage drop is
V = IZ = (ICosφ1+jISinφ1) (R+jX)
(Though Finally if you simplify it to the modulus (non phasor values) and it may simplify to something like
V = IZ(Cos(φ1+φ2) + jSin(φ1+φ2)) = |IZ|
This is what must be taken for the drop calculation. As far as I know the cable ratings and calculations are dependent on load current (and thus it does take care of the powerfactor of I) and then there are some standard multipliers (must be for the cable reactance).
But again it is IMHO since I do not indulge in cables.
Good Answers: 244
07/14/2011 9:32 PM
This thread (especially the comment #12 and #14) may be related to the discussion: http://cr4.globalspec.com/thread/65251/Voltage-Drop-Calculation-for-Single-Phase
- MS
Register to Reply 10 comments
Anonymous Poster (1); msamad (1); nikolay (1); North of 60 (1); PWSlack (1); Salunkhem (1); TonyS (1); Tornado (3)
