Previous in Forum: Main Reinforcement Direction   Next in Forum: Compressive Strength of Cube
Compressing Strength of Cube
06/16/2011 2:02 AM
For M30 grade of concrete if the value of 7 days and 28 days results found differ from the design value(Means instead of 20.1 for 7 days it comes 23.0,25.0 and for 28 days it instead of 30 it comes 35.0,40.0) then the result will failure or not?
Re: compresing strength of cube
06/16/2011 2:10 AM
?? In each case, it sounds as though the concrete has exceeded the specifications.
06/16/2011 7:20 AM
Not.
Re: Compressing Strength of Cube
06/17/2011 11:14 AM
Are you concerned that the concrete is too strong? the break results show it is stronger than the minimum design specification. In most applications I have ever dealt with this is fairly typical and what you would normally expect on good concrete. Many times the plants and/or subcontractors call for something slightly stronger just to make sure they make the minimum design strength.
Good Answers: 74
06/20/2011 1:10 PM
RCE,
Isn't it also true that cube tests provide higher apparent strengths than cylinder tests?
Bruce
06/17/2011 12:52 PM
Pineapple
ba/ael (1); lyn (1); Pineapple (1); RCE (1); Tornado (1)
