Previous in Forum: Need Information on Getting Accepted at a Good US University   Next in Forum: What about USF?
22 comments
Doppler Shift for Accelerated Motion
06/18/2011 9:19 AM
I was talking to one of my friends the other day about doppler effect and we went into the discussion of accelerating object and doppler effect. we both agreed that the frequency shift would vary in time. then we argued about the frequency shift for different observers and here is were it got interesting, after arguing for some time we took an example:
say there is a sound source emitting frequency f0=1kHz that starts accelerating from the origin from rest with acceleration a to the right at time t=0s. say also we have a observer at x=-1m, what I argued that at time 1/300s (time taken sound to travel from the sound source at origin to x=-1) the observer will start recording a frequency of f0 and then this frequency will start declining with time. similarly an observer at x=-2m will start recording frequency f0 at time 2/300s and that frequency will start declining with time. (see fig1 for illustration)
Fig1
a consequence from the above image is that if say you take a specific point in time t=T where T>2/300s, at this specific time instance T each observer would register different frequency (see fig2). this too made sense since the signal received by observer one at t=T was emitted by the source at an earlier point in time than the one received by observer 2 at the same time t=T (due to propagation delay [the time it takes the signal to reach the observer] and due to the fact that the speed of sound is finite), which the speed of the source when it emitted the wave that was received at t=T by observer one is different than the speed of the source when it emitted the wave that was received at same time t=T by observer two. and due to this speed difference I reasoned that there should be a frequency shift between the two observers at time t=T (or any time instance for that matters)
Fig2
This reasoning made sense to me, but then my friend told me I was wrong and pulled of a pencil and paper and manipulated some equations to prove that both observers at x=-1 and x=-2 receive the same frequency at all points in time. his formulas made sense but then what is wrong in my previous reasoning?
Fig3 illustration of case study
The third image is the image of the whole setup.
I'll include an image of the formulas (the ones my friend solved) in a very clear and easy to read format and another clear text copy (in case the image link fails)
the formulas:
in image format:
case image link fails:
Transmitted signal:
s(t)= A_t sin(2πf_0 t)u(t) - Where u(t) is the unit step function
Received signal:
s_r (t)= A_r sin(2πf_0 (t-∆t))u(t-∆t)
∆t=d/c Where d is the distance between transmitter and receiver
And c is the speed of sound
After substitution we get:
s_r (t)= A_r sin(2πf_0 (t-d/c))u(t-∆t)
Now d is not fixed. Using kinematic formulas we get:
d=1/2 at^2+v_0 t+x_0
=> s_r (t)= A_r sin(2πf_0 (t-(1/2 at^2+v_0 t+x_0)/c))u(t-∆t)
=> s_r (t)= A_r sin(2πf_0 (t-1/2c at^2-v_0/c t-x_0/c))u(t-∆t)
=> s_r (t)= A_r sin(2πf_0 (-1/2c at^2+(1-v_0/c)t-x_0/c))u(t-∆t)
=> s_r (t)= A_r sin(2πf_0 (-1/2c at^2+(1-v_0/c)t)-(2πf_0 x_0)/c)u(t-∆t)
=> s_r (t)= A_r sin(2πf_0 t(-1/2c at+1-v_0/c)-(2πf_0 x_0)/c)u(t-∆t)
Now from the above we see that the frequency at each point in time is:
f=f_0 (-1/2c at+1-v_0/c)
This means that the frequency is the same at each point in time no matter what x0 is!
The only place x0 enters in the picture is in the phase of the signal: φ=-(2πf_0 x_0)/c
This means that observe one and observer two will always register the same frequency.
The received signals only differ in phase φ_1=-(2πf_0 x_1)/c,φ_2=-(2πf_0 x_2)/c
SO WHAT GIVES WHAT IS WRONG IN MY INITIAL REASONING?
regards
Re: Doppler shift for accelerated motion
06/18/2011 10:56 AM
Never mind, I mis-read the part about the sound source accelerating.
What does the prof have to say?
06/18/2011 11:37 AM
If I've read and understood your words correctly, I see two errors.
The first error involves the distance d. The distance d is a term for the distance to a specific observer, not all observers. You could have d1 for an observer at a x=-1 and d2 for an observer at x=-2, etc. Generically you can use the term d, e.g. for an observer at the origin, but when you are talking about a specific observer at a specific observing location you need to designate which observer, i.e., at which distance.
The other error is in your statement about the frequency being the same at each point in time. In fact the equation you give for f includes a term for t which must affect the sum for f as t increases. (Note I've made t bold in the equation below for emphasis.)
f=f0 (-1/2c at+1-v0/c)
The result f cannot be a fixed value unless t is constant, but clearly time is not a fixed, constant quantity; it increases continually.
At least, that's what I see. Perhaps I've misinterpreted something?
06/18/2011 1:03 PM
I didn't define x0 properly x0 is the initial distance between the transmitter and the receiver so for observer one x0=1m and for observer two x0=2m.
and when I solved the equations I solved them for any observer all you need to do at the end is substitute the x0 for that specific observer
as for the instantaneous frequency you're right its the derivative of the phase so it should be:
f(t)=f0(-a/c t - v0/c + 1)
so indeed its still increasing with time but again is still independent of x0. this means that no matter where your position is the frequency measured at any specific time instance is the same.
I'm really obsessing about this now so please help I need to get some sleep :D
06/18/2011 6:39 PM
I think you've just shifted your error in thinking from d to t. For any given observer, the observer's distance is di. Correspondingly there will be a ti, which is not the same for every observer.
06/19/2011 10:48 AM
actually I accounted for the ti your talking about early in the proof when I moved from the transmitted signal st(t) to the received signal sr(t). where I said sr(t)=st(t-∆t) with some attenuation ofcourse. and then from the ∆t, d entered the equation.
06/20/2011 8:12 AM
You are still making the same error, you just keep going around yourself.
You define:
∆t=d/c Where d is the distance between transmitter and receiver and c is the speed of sound
sr(t)= Ar sin(2πf0 (t-d/c))u(t-∆t)
d=1/2 at2 + v0t + x0
What you have done is inter-posed different meanings of d. When you define d=1/2 at2+v0 t+x0 , you have defined the distance 'd' of the moving transmitter from the origin x0. So when you do your substitution ∆t=d/c , where have you accounted for the extra distance for observer 2 at position x = -1 and observer 1 at x = -2 from x0? You haven't. You're using the same 'd' for the distance of the emitter from x0, for the distance of the emitter from observer 1 and for the distance of the emitter from observer 2. Clearly an extra bit of time is needed for the transmitted signal to cover the extra distance from x0 to x = -1 and then a little bit more beyond that to reach x = -2.
So even though you think you have a general equation for calculating the signal anywhere, in fact your equation only calculates the signal at x0 -- where, as you agreed earlier, the signal does show a decreasing frequency with time.
06/20/2011 2:07 PM
I never said x0=0. x0 is the initial distance between the transmitter and the receiver for any arbitrary receiver. i.e for observer 1 x0=1 for x0=2, and you could see that when I substituted for the different observers to find phi1 and phi2 near the end and deduced that the frequency received is the same and that the only difference is in the phase
regards
06/20/2011 8:22 PM
In your figure 3 you clearly state x0 = 0.
You can argue and be defensive, or you can listen to advice. You continue to state that 'the frequency is the same' when common sense tells you that each observer will see (or hear) a slightly different frequency due to the slight difference in position (and therefore propagation time) of the wave as the emitter accelerates away.
So, like, whatever...
06/21/2011 2:00 PM
dude I'm being defensive for a reason, I just would like to have a solid argument cause its science after all.
I can see the logic! I mean I'm fighting my friend to prove that each user hears a different frequency from the first place! I just want to present a mathematical argument or at least point out to where exactly his equations are wrong.
and as for the x0 in figure3 thanks for pointing that out its just a mix up, what I meant here is x0 for this user. maybe I should pick a different name for it, I'll change that shortly
regards
06/18/2011 12:04 PM
06/18/2011 12:13 PM
How about the case of extreme acceleration, where the sound from the source could be considered as a packet, rapidly decreasing in intensity. If the acceleration were sufficiently high, the sound heard by the observer nearer the source could be all over and done before the second observer even started to hear it. (May need to make the separation between the two observers bigger to more easily think it through).
I believe that the range of frequencies would indeed be the same (albeit at different intensities), but they couldn't possibly be heard at the same time by both observers.
06/18/2011 1:42 PM
excellent idea to tell you the truth I was just thinking about that. but that's all poetry if we don't have hard proof, and my friend's equations are hard proof so unless there is something wrong in his equations I can't say he is wrong! science is about hard evidence and mathematical proofs not feelings and intuition, at least that's what my friend told me after he hit me with his equations :(
something doesn't add up here! what is it?
06/18/2011 5:53 PM
I gave up doing sums like that many years ago. I still use maths in my work, but the applications require a different approach - I'm not going back to my text-books for this, life's too short.
Surely the Gedanken (thought) experiment I presented is "hard enough" proof? How could your friend refute the conclusion?
You could demonstrate the "proof" easily, with the help of a third friend, a starting pistol and a bit of open space[1]. A video camera on a tripod, recording the responses, should seal it. The doppler effect is irrelevant - if the observer further from the source has not heard it, it can't possibly be at the same frequency as that heard by the nearer observer.
The error must lie in his "equations".
[1] You seem to be a smart bloke - I hope I don't need to spell this out further.
06/19/2011 10:23 AM
thanks for your spot on comments John, but as I told you I need to know what's wrong in his equations
And
You could go even further with your thought experiment if the source only transmits for say 1 second and you position your observers in such a way that the near observer stops hearing anything before the far observer even starts hearing!!!
Good Answers: 114
Re: Doppler Shift for Accelerated Motion
06/18/2011 6:26 PM
The varying frequency which you assume is only true if the listener(s) are outside the line of travel of the sound source. If the listener is in, or close to, the line of he sound source, and if the source is moving with constant velocity, the listener will hear a constant frequency.
Imagine a source that is moving towards the listener at one tenth the speed of sound. The first peak is emitted and reaches the listener, the source moves one tenth of a wavelength toward the listener and issues the second peak, this second peak travels one tenth of a wavelength less so arrives one tenth of a wavelength early, the listener hears the peaks arriving at a constant nine tenths of the emitted wavelength.
When the source passes the listener, the frequency drops because the source is moving away and the listener hears a wavelength of eleven tenths of the emitted wavelength.
If the listener is far off the line of travel of the source, the frequency will change with time because the distance between the source and the listener changes non-linearly because of the angle of the direction of travel changes.
Re: Doppler Shift for <u>Accelerated</u> Motion
06/18/2011 6:29 PM
"... and if the source is moving with constant velocity".
Missed the point, here - read the OP more carefully.
PS. The title of the thread (including that of your post) is a bit of a give-away.
Good Answers: 114
06/18/2011 6:39 PM
Oops.
Needs thinking about. What speed when the source passes the listener.
Must prevent this from getting into Mr. Einstein's Relativity at any price.
Good Answers: 88
06/18/2011 7:13 PM
Between the two listeners (concidering both and moving sound sourse are on the same line) ther's only a time delay t=x/c.(x being the distance between them) But at this time delay the sound sourse had (meaning had) also increased its v by t*acc. So at the same time and with an accelerating sound sourse the two listeners will perceive different frequencies but only because their different locations. The sound print in space the source leaves is one and only. But since you like to make a basic problem difficult, here's a less obvious one: What happens when object hits sound speed? S.M.
06/19/2011 12:57 PM
no assume the velocities here are well bellow the speed of sound.
and that's my point exactly a time delay should reflect a frequency delay due to the accelerated motion. but have a look at the equations that my friend solved they are pretty solid :( I couldn't refute them
Good Answers: 88
06/19/2011 1:05 PM
Differenciation is not exactly reverse of indegration. There is an emerging (unknown) constant involved in integration. In this case it's the distance between listeners. S.M.
06/20/2011 1:29 PM
the proof image got scaled down for some reason so here is the link for it:
https://sites.google.com/site/javascriptevents/home/Proof.jpg
Good Answers: 114
06/23/2011 1:17 PM
I have a problem with non-dimensional, ill labelled diagrams, so here is mine (sorry it's hand drawn but I don't have a drafting program).
It is a space time diagram, the vertical axis in seconds and the horizontal in "space seconds", each being the distance traveled by sound in one second. An emitter, one beep per second, starts from the origin and accelerates at a rate of 0.1 space seconds per second squared along a straight track. There are observers at intervals out on the track who only travel in time but are stationary in space.
The beep that is emitted at the end of each second, travels backward and forward along our space dimension and forward with time.
The observers see the same pattern, delayed by the distance between them, until the emitter passes one of them, then there is a break until it passes another when they each are the same pattern but delayed in the opposite direction.
At 10 seconds, the emitter reaches the speed of sound, so I didn't try any further.
Register to Reply 22 comments
Anonymous Poster (1); JohnDG (3); lyn (1); maa105 (8); passingtongreen (3); SimpleMind (2); Usbport (4)
