Previous in Forum: Transformer Synchronization   Next in Forum: Help on 5th Harmonic Tuned Filter Required
Why We Run Motor in Delta Not in Star Connection
06/22/2011 2:25 PM
We start a 25 HP motor in star delta startor why not run in star connection countinue
Luxmi Maurya
Re: Why We Run Motor in Delta Not in Star Connection
06/22/2011 10:16 PM
Because you get only 1/3 of the motor's rated torque and hp if you leave it in star.
Good Answers: 21
06/23/2011 4:12 PM
You could also ask why not start in delta configuration then you might find the answer to your original question.
06/24/2011 1:55 PM
(1) you can't because the timer in star-delta starter will put motor in delta after settee time. (2) you may continue motor in star provided your load requirement is less. In this case you are un-necessarily selected higher rated motor. Commercially wrong decision. Instead you can have delta connected lower rated motor on DOL starter. Hope this satisfies your query...
Engineering is an APPLICATION..
Register to Reply 3 comments
MACA (1); Salunkhem (1); Tornado (1)
