Previous in Forum: Embedded Web Server   Next in Forum: Invetor Circuit
12 comments
Solar Panel
06/27/2011 1:11 AM
I Have purchased solar panel plate, which having capacity 10watt, 19.2v,
my question is that what happens if the output wire of solar panel is short circuit.
Hobbies - Fishing -
Re: soler pannel
06/27/2011 1:16 AM
Nothing.
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
Re: soler pannel
06/27/2011 4:32 AM
why explain it
Hobbies - Fishing -
Re: soler pannel
06/27/2011 12:28 PM
My apologies, I redact my answer. I read "short circuit" as "open circuit". Do not short circuit your panels as you will damage the cells.
Good Answers: 46
Re: soler pannel
06/27/2011 2:21 AM
.5 amp. short term most likely nothing. Long term the solar cells that make the panel will be damaged.
Although I've not had much experience with solar panels, batteries and power supplies (some designs) were not hurt with a brief touch of the wires together.
With the solar cells the short circuit could open traces or overheat the cells and damage them or damage the wiring.
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Re: soler pannel
06/27/2011 4:28 AM
ok in this case its is .5amp. if there is 500watt and and 19.2 then the current is almost 25amp wich may bi to much. it can damage solar plate quickly
Re: soler pannel
06/28/2011 12:33 AM
How are you getting 500 watts to be associated with a 10-watt solar panel?
Re: soler pannel
06/27/2011 4:26 AM
The circuit protective device, if correctly selected and installed, will operate, thereby disconnecting the cell(s) from the downstream circuits and minimising the risk of damage to each.
Popular Science - Weaponology - New Member Engineering Fields - Control Engineering - New Member Engineering Fields - Electrical Engineering - New Member
Re: soler pannel
06/28/2011 6:52 AM
hello,
i think nothing will happen when you short circuited the terminals of solar panel because when you shorted the terminals of solar panel very small current flows through the solar cells which hardly damage the cell so, i think no problem occur
on the other hand protection circuit is there which protect the circuit from any kind of damage like short by wind, heavy rainfall etc.
so, anything will happen if you short circuited the terminals of solar panel
knowledge is increased by sharing!!!!!!!!!!!
Re: soler pannel
07/01/2011 1:29 PM
i need very sure answer
Hobbies - Fishing -
Re: soler pannel
07/01/2011 1:33 PM
Why do you want to short circuit the panel?
Good Answers: 116
Re: Solar Panel
07/06/2011 10:39 AM
Find solar panel including data sheet at Farnell. http://www.farnell.com/datasheets/925855.pdf The data sheet shows an area of 0.1 square metre with 10W output at 1000W/sq.m solar radiation. That makes 10% efficiency. Short circuit current is 0.6 amp and is sharply defined - hence the device is self-current-limiting. 10W means 10 milliwatt per square cm. That is so low, I think this device is short circuit proof.
Re: Solar Panel
10/28/2014 12:06 PM
Register to Reply 12 comments
67model (1); lighthasmass (3); metalSmiths (1); PWSlack (1); sajal mittal (1); shelbyjones (1); tahir mumtaz (3); Tornado (1)
