Previous in Forum: Phase Sequence of Compressor   Next in Forum: Hydrostatic Head to be Considered to Carry Out ASME Code Calculation.
8 comments
vapor pressure
06/27/2011 11:35 PM
I am selecting a seal for vs4 pumps when the fluid is water and its temperature is 260 C but the vapor pressure is only 0.11 bar a. when i looked at graph for temperature and vapor pressure for water is around 40 bara. my question is there any possibility to reduce the vapor pressure at box side.
Need your help
Regards
Re: vapor pressure
06/28/2011 1:03 AM
can you elaborate, what do you mean box side? i think this will be clearer if a simple diagram with label is presented.
thanks.
Re: vapor pressure
06/28/2011 1:15 AM
thanks for your reply.
what i meant was pressure at stuffing box side.
Regards
SLN
Re: vapor pressure
06/28/2011 1:33 AM
there's no way you can reduce vapor pressure but by lowering the temperature of the fluid inside.
Re: vapor pressure
06/28/2011 1:39 AM
Thanks for your help.
vapour pressure is given in pump datasheet supplied by end user/pump manufacturer. I am not trying to reduce it. is there any reducer fitted between stuffing box and impeller in case of vs4 pump(API pump classification)
Regards
SLN
Re: vapor pressure
06/28/2011 1:52 AM
vapor pressure given by the manufacturer also connotes the temperature of water to be handled. and the actual application is on 260 degC? in that case you will subject your pump to an extreme temperature beyond its design, this result to a disaster.
better ask the OEM if their equipment can handle this condition.
Re: vapor pressure
06/28/2011 2:16 AM
0.11 bara and 260°C sounds more like superheated steam than water.
Re: vapor pressure
06/29/2011 4:24 AM
0.11 bara is below atmospheric and is a vacuum condition. Water cannot exist as liquid at 260 deg. C and this pressure. If water has to exist as a liquid in equilibrium with vapor at 260 C, it has to be under a high pressure such as what you have found from the tables. The stuffing box has to be designed suitably to stand a pressure of 40 bara and a temp. of 260 C. on the innerside and atmospheric pressure on the outer side.
Re: vapor pressure
08/25/2023 8:12 AM
Er, um, <...water...> at <...260 C...pressure...0.11 bar a...> is actually superheated steam. It cannot exist in contact with liquid at these conditions, as the <...water...> will boil.
Register to Reply 8 comments
kasharma (1); lito (3); PWSlack (1); sln (2); Tornado (1)
