Previous in Forum: I Need Help Finding The Right Electronic Component.   Next in Forum: soler pannel
soler pannel
07/03/2011 11:54 PM
I Have purchased solar panel plate, which having capacity 10watt, 19.2v,
my question is that what happens if the output wire of solar panel is short circuit.
Re: soler pannel
07/04/2011 12:02 AM
You asked this same question a week or so ago.
10 watts ÷ 19.2 volts ≈ 0.52 amps. If the wire is too small, it will burn up. If not, probably nothing will happen, but I'm not sure.
Re: soler pannel
07/05/2011 1:03 AM
It just gets a little hotter in the sun. It can't get any hotter than it would if it were painted black or if it could be a near perfect black body absorber. Since it isn't it won't get that hot because some energy will be reflected. So effectively, nothing happens. Or another way to look at it is 0.6 amps x 0 volts = 0 watts. Of course there will be a voltage across the cell equal to the current developed x the effective resistance of the cell but still, not something to write home about...
Popular Science - Weaponology - New Member India - Member - New Member
Re: soler panel
07/05/2011 1:15 AM
try once.
Cause practical knowledge is always better than theoretical.
Register to Reply 3 comments
rcapper (1); sanjaykangralkar (1); Tornado (1)
