Previous in Forum: 4 Wire Transmitter, Zone 0   Next in Forum: FF Instrument Testing
Flow Switch
07/09/2011 2:03 AM
Hello!
Im looking for a flow switch that can works in a vertical line.
please introduce proper flow switch type.
Best Regards!
Re: Flow Switch
07/09/2011 2:20 AM
use 'Danfoss' make switches
Blessed is the man who finds Wisdom, the man who gains understanding. Proverbs:3:13
Re: Flow Switch
07/09/2011 3:46 AM
Thank you Macsimus!
but im looking for the proper switch type not a brand. I mean for example paddle type or calorimetric, etc. And please attend that the fluid is water.
Engineering Fields - Instrumentation Engineering - Global Technical Village Engineering Fields - Control Engineering - Control Automation Engineering Fields - Biomedical Engineering - Engineering Philianthrophy Engineering Fields - Electromechanical Engineering - Electromechanical Tacho Engineering Fields - Engineering Physics - Physics change you life Engineering Fields - Energy Engineering - Save earth Engineering Fields - Environmental Engineering - Human Recycle Engineering Fields - Mechanical Engineering - We move earth Engineering Fields - Nanoengineering - Minute study Engineering Fields - Systems Engineering - Systems in Place
Re: Flow Switch
07/10/2011 5:18 AM
Dear friend, pls mention your application first:
What is the media
What is the temperature
What logic you need
What is the line size
Once you make application clear then as you said what type is required to your need can be judged bases on availability of the product in local market.
How ever to make you select easily there are basically 2 types of flow switches which are commonly stocked in India by many manufacturers :
Adjustable Vane type( with adjustable vanes to meet line size requirement)
Flap type ( working some what as that of a check valve)
For water, hydrant and utility application commonly vane type is recommended as this line does not have much of process parameter criteria while selecting as water at 10 kg/cm2 with max. 40 - 60 deg. C suits to many of the application as cited above
Rest of the appications for chemicals / alkalines / acidic compositions / solvents etc. needs to be of flap type but for these applications you need to cautious of auxiliary power supply as most of the solvents are highly intrinsic and consider static charging. So the enclosure should be of IP65 for common applications & FLP ( Class II A & IIB) selections has to be done as per the media.
One who is afraid to ask is ashamed to learn
Re: Flow Switch
07/10/2011 11:06 AM
What is your Vertical Water Pipe Size?.
What Pressure above atmosphere ?
Above what Flow rate do you want signal 1 ?
And below what flow rate can it signal 0 ?
A simple paddle type with a diaphragm or bellows seal can be rigged up.
You can do it yourself if you have a basic Instrumentation workshop .
If you cannot I can help you
Tell us
mm
Re: Flow Switch
07/10/2011 5:06 AM
Try Capacitive flow sensors. They can be installed in either plane.
Re: Flow Switch
07/11/2011 4:00 AM
Thermal flow switches work in any direction of line.
Register to Reply 6 comments
askaripour (1); Jaya Krishna (1); Macsimus (1); MUKULMAHANT (1); No_eing (1); PWSlack (1)
You might be interested in: Gas Flow Meters, Vertical Conveyors, Flow Meters
