Previous in Forum: Neutral Shift in Star Side   Next in Forum: System Fault Current
AC Motor with Frequency Controller for Changing RPM
07/11/2011 4:33 AM
I am in need of a Frequency controller which can change RPM of AC Motor (Rating less than 1 HP) as we want with change in frequency. e.g. If I want RPM at some time 203 RPM and then 204 RPM and then 205 RPM....Suggest me the instrument which can do this thing.
Paresh B. Gujarati
Re: AC Motor with frequency controller for changing RPM
07/11/2011 4:48 AM
It's called a variable frequency drive, and they are readily available on the open market.
New Zealand - Member - Kiwi
Good Answers: 29
07/11/2011 3:31 PM
As PWS has said, use a VFD. Note, though, that you will need your motor to be of the 3-phase induction type to work with a VFD.
paulusgnome
Register to Reply 2 comments
You might be interested in: AC Motor Drives, DC to AC Converter Chips, AC Motors
