Previous in Forum: Compressed Air Pressure   Next in Forum: PN 16 and PN 18 Differences?
Stub In & Stub On in Piping
07/12/2011 12:46 AM
Hi to all
Can some help me, what is the criteria to identify the STUB IN & STUB ON in piping?
How to calculate the duration of oxy-acetylene cutting in dia inch.
Pathfinder Tags: piping engineering.
Re: Piping engg.
07/12/2011 1:02 AM
For "stub in," the stub or branch pipe extends to the inside of the main pipe. The hole in the main pipe is (usually) beveled to allow for a full-penetration weld. For "stub on," the stub extends only to the outside of the main pipe. The stub may be beveled, but if not only a fillet weld can be done. "Stub in" is generally stronger, and often much stronger.
Oxyacetylene cutting duration is roughly proportional to distance traversed times thickness of material; not diameter alone.
Good Answers: 38
Re: Stub In & Stub On in Piping
07/12/2011 11:24 AM
banu....
Both "STUB-IN" and "STUB-ON" are notoriously weak branch connections on piping systems. Often times, this type of branch connection is restricted to low pressure applications.
Both types are permitted by many of the international codes of construction, but with limitations on thier application. In many of these codes, they are called "UNREINFORCED BRANCH CONNECTIONS".
As I recall, they are banned from B31.3 Category M (lethal) service....
07/13/2011 9:25 AM
Free download this file: Acceptable_Pipe_Branch_Connectioin.
Note. Set-in have the same meaning of Stub-in & Set-on have the same meaning of Stub-on.
02/06/2017 9:09 PM
i need some clarification about stub end .
why we use stub end ? whether is to make a connection to polished material or anyother.
please help me to get cleared. am new to this sector.
02/21/2024 3:30 AM
<...we...>
So there is more than one person at the facility though the number is indeterminate. Try asking around.
Stub In & Stub On standard
08/24/2017 1:07 AM
Hello
I look for standard Asme explain stub in or on and when we can use each of them .
Can they used with reinforcing pad (stub in & on) ?
Thank you
Register to Reply 6 comments
Abdel Halim Galala (1); jafary64 (1); MJCronin (1); pursothaman (1); PWSlack (1); Tornado (1)
You might be interested in: Piping Services, Piping Systems, Cutting Services
