Previous in Forum: Toshiba Super Modular AC   Next in Forum: Generalized Formula for Relativistic Kinetic Energy of Spinning Rotor
8 comments
Heat Exchanger
07/12/2011 4:59 AM
In case of heat exchanger, we have following data available:
ID of shell: 1100mm
Tube O.D.: 19.04mm
Pitch on tube sheet: 25.4mm
Please tell us how to calculate possible number of tubes in exchanger?
Pathfinder Tags: heat exchangers
Re: Heat Exchanger
07/12/2011 5:22 AM
You can't get there from here.
You also need to know the process and heat exchange fluids, the temperatures at the inlets, and the desired process fluid outlet temp (among other things).
You should really get a book on heat exchanger design. Once you have the design, have it checked by a real engineer. This isn't something you should rely on answers from an open forum for.
Or maybe this is a homework question. If so, if you want to learn anything at all, put some effort in and study the textbook and class notes.
Re: Heat Exchanger
07/12/2011 5:23 AM
Use triangles on a drawing. Set-out the matrix so that the number of tubes fits into the shell diameter.
Re: Heat Exchanger
07/12/2011 5:34 AM
Different heat exchangers have different goals, for example, low cost, high efficiency (defined in different ways), low weight, high corrosion resistance, low (or high) pressure drop for one (or both) fluids, etc. Message from #1 is correct
Good Answers: 137
Re: Heat Exchanger
07/12/2011 5:58 AM
But you (and Mikerho) are answering a question he hasn't asked. He's already decided dimensions and if he hasn't taken account of your criteria it's his hard luck!
The question he's asked is just a geometrical one, and PWSlack has answered it.
Codey
Re: Heat Exchanger
07/12/2011 6:22 AM
Thank you. PWSlack's answer is good, but some things are left out, like there is a reference to drawing. Is the suggestion including making a drawing? (!) How close to the shell do you want the tubes? Are you then supposed to count the tubes? Drawing the end view and counting the tubes sounds too low tech for this job.
PS with variable K you still do not have a number. See next
Re: Heat Exchanger
07/12/2011 6:32 AM
Bingo!
Re: Heat Exchanger
07/12/2011 6:18 AM
Hi to all,
Thanks for every one for their suggestions as per his knowledge finally i got formula and want to share to all might be helpful to any other that is
No of tubes in HE = .782*D*D/(K*Pitch*Pitch)
Where D = Shell diameter
K = Tube constant it may vary from 1.2 to 1.8,
Pitch = Tube sheet pitch.
Re: Heat Exchanger
07/13/2011 12:14 AM
Is there an explanation that goes with this formula?
(Where does 0.782 come from? What is "tube constant"?)
Register to Reply 8 comments
Codemaster (1); gmathur189 (1); Mikerho (1); PWSlack (2); Tornado (1); woodpower (2)
