Previous in Forum: Cooling Technology For Future Nuclear Reactors   Next in Forum: 3D Copying
13 comments
Deburring Fibre/Resin Holes
07/13/2011 9:56 AM
I cannot reveal too much of my customers process however, he is required to make a number of radial holes ranging from 5/16"-1" dia, from inside a long pipeline 4" to 12" dia. All the drilling is done remotely using a camera and drill mounted on a trolley. The material being drilled is a hardened, fibre reinforced resin around 1/8" wall thickness. I supply the special drills, however, am unable to come up with an adequate means of removing the "burrs" or torn threads. Even using a "clean cutting" hole saw" type bit, we are left with loose and torn fibres. Best results are from using a rotating end type steel wire brush (0.005" wire) which we run as a separate operation. We would ideally like a clean entry into and through the hole. Any suggestions are appreciated.
Jim...
Re: deburring fibre/resin holes
07/13/2011 10:00 AM
Heat.
Or perhaps the new LynDoor™ EHAT process... sort of like this:
Good Answers: 18
07/13/2011 10:10 AM
Hi Doorman,
FOMCL (Fell Off My Chair Laughing)
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
07/13/2011 10:11 AM
On the outside bottom of your regular drills, and on the outsides of your hole cutting drills, apply adhesive and emery or some other suitable abrasive.
My thinking is, that after your hole is cut, the final bit of drill would resemble a drum sander, and clean up the hole.
It might take some experimentation, but some variation of this might work.
07/13/2011 12:19 PM
You might even be able to machine a relief in the shank of the drill to accomodated a sanding drum of the right size.
(I like knurling, myself. No xtra abrasive particles to gum up the works)
07/13/2011 12:38 PM
...knurling myself!
07/13/2011 1:08 PM
It feels soo good when you stop.
Good Answers: 150
07/13/2011 1:00 PM
I could see grinding a shallow relief as well as a thin slot (probably have to wire edm that slot.) to slide the emery cloth through to essentially turn it into a flapwheel.you might need to wire edm some roll pin holes at 90 degrees to hold the emery paper in place.
Who is John Galt?
07/13/2011 10:33 AM
That's a tall order. As long as you are dealing with fibers, it will be tough.
Can you knurl a 1/4 inch length of drill shaft, just after the flutes? The knurling may act as a grinder to clean out the fibers left after drilling. If it works, one pass and you're done.
Good luck.
07/13/2011 2:12 PM
Good idea, I will make a sample and try this next time I run the job.
Good Answers: 150
Re: Deburring Fibre/Resin Holes
07/13/2011 12:48 PM
They make spring loaded Titanium Nitride coated deburring tools that can debur both the front and back sides of holes in one pass from the front side. but I'm not sure how they'd work for Phenolic/fiberglass/etc.
here is one manufacturer:
http://www.ezburr.com/index.php
they make a burr free drill with both a drill and a deburring tool in one.
Who is John Galt?
Good Answers: 266
07/13/2011 3:09 PM
Where in the hole are the loose fibers?
The inner part can possibly be address with a self chamfering drill bit.
Would also look at the cutting edge of the bit.
As you give no details of what the fiber is. Though 1" diameter is quite large have you tried circuit board drills or looked at the cutting edge on such a bit?
Good Answers: 74
07/13/2011 10:36 PM
Hi Jim
Could you apply a thin layer (3-5mm) of a semi-hard setting compound and drill through both and then remove the compound and all fibers at the same time? You would have no burs in the first place and removing the patch could be done chemically or by just peeling it of.
I'm not inside the pipe more outside the box.
Hope you don't need a drawing
Good luck, Ky.
The Twain Has Met
07/14/2011 8:05 AM
Diamond Diamond Diamond-- I have worked with carbon fiber and resin before. Try to find diamond coated bits. Carbide will hold up for a little bit time, but diamond coated bits are the best for cost vs length of use.
Register to Reply 13 comments
bestmurf (1); Doorman (2); jesw55 (1); jimmymac28 (1); kramarat (1); ky (1); lyn (3); ozzb (1); Rorschach (2)
