Previous in Forum: Can We Upgrade Normal Welding Machine To High Frequency Machine For TIG.?   Next in Forum: Calculating Steam Turbine Efficiency
Seamless or Welded Fittings
07/16/2011 7:03 AM
Dear Experts,
Vendor supplying double seam welded fittings with a joint factor of 1 (100%RT and welded from both side) but Client is rejecting saying that Single seam is allowed but double seam is not allowed at all...
ASME Sec viii div 1, UW-12 part e says that seamwelded to be treated in same way as of seamless with some conditions related to allowable tensile stresses for welded part not exceeding seamless part.... i referred ASME sec ii Part D Table A but could not help myself as i am not design engineer.
Requesting experts to share their thoughts.
Regards
Manpreet Singh
Re: Seamless or Welded Fittings
07/17/2011 11:05 AM
Manpreet,
I believe the most important issue for you to address here is the Client's request. Were there drawings and/or specifications available for this project before you started ? Did you and your Client have a pre-project meeting to discuss his expectations and requirements ? What would make your vendor supply something that you did not specify ? You have not provided much information on the use of your intended fittings, but I am afraid you are going to have to follow the old adage "the customer is alaways right" even if it seems to defy logic.
"Money talks I know, I heard it once, it said Goodbye”
Good Answers: 34
07/18/2011 9:16 AM
Diameter? Thickness? Pressure? Temperature? Service?
Good Answers: 34
07/18/2011 12:04 PM
Sorry, my anwers is suppose to be post for Manpreet
07/17/2011 9:59 PM
I am imagining a piping category called "almost seamless", in which one seam is allowed, but no more. It seems the client has beat me to this weird idea. I wonder why they would accept one seam, but not two.
07/18/2011 3:10 AM
Please go through the standard A234 according to which welded fittings are made. Unless and other wise spcified in the order, manufacturer can supply welded fitting as per order. Part of the standard is pasted here for your ref. from description it is clear that welded jints can be more then one.
SA-234/SA-234M 1998 SECTION II
2.5 ASNT Standard:
SNT-TC-1A(1984) Recommended Practice for Nondestructive
Testing Personnel Qualification and Certification
3. Ordering Information
3.1 Orders for material under this specification shall
include the following information:
3.1.1 Quantity (number of fittings of each kind),
3.1.2 Description of fitting and nominal dimensions
(standard or special),
3.1.3 Steel composition by grade and class designation,
3.1.4 Construction, seamless or welded (unless
seamless or welded construction is specified by the
purchaser either may be furnished at the option of the
supplier),
3.1.5 Additional requirements, if any, (See
17.5), and
3.1.6 Supplementary requirements, if any.
4. Materials
4.1 The material for fittings shall consist of killed
steel, forgings, bars, plates, seamless or fusion-welded
tubular products with filler metal added and shall conform
to the chemical requirements of Table 1. Unless
otherwise specified for carbon steel plates, the steel
may be made to either coarse grain or fine grain
practice.
4.2 A starting material specification that specifically
requires the addition of any element beyond those listed
for the materials in Tables 1 and 2 and for the applicable
grade of material is not permitted. This does not
preclude the use of deoxidizers or the judicious use
of elements for grain size control.
5. Manufacture
5.1 Forging or shaping operations may be performed
by hammering, pressing, piercing, extruding, upsetting,
rolling, bending, fusion welding, machining, or by a
combination of two or more of these operations. The
forming procedure shall be so applied that it will not
produce injurious imperfections in the fittings.
354
5.2 Fittings machined from bar shall be restricted
to NPS 4 or smaller. Elbows, return bends, tees, and
header tees shall not be machined directly from bar
stock.
NOTE 1 - Fittings NSP-4 and under may be machined from hotforged
or rolled, cold-sized, and straightened bar stock having the
chemical composition of the grade in Table 1 and the mechanical
properties of the Grade in Table 2. Heat treatment shall be in
accordance with Section 6. All caps machined from bar stock shall
be examined with by liquid penetrant or magnetic particle in accordance
with S3 or S4.
5.3 All welds including welds in tubular products
from which fittings are made shall be (1) made by
welders, welding operators, and welding procedures
qualified under the provisions of ASME Section IX,
(2) heat treated in accordance with Section 6 of this
specification, and (3) radiographically examined
throughout the entire length of each weld in accordance
with Article 2, ASME Section V with acceptance limits
in accordance with Paragraph UW-51 of ASME Section
VIII, Division 1 of the ASME Boiler Pressure Vessel
Code. In place of radiographic examination, welds may
be ultrasonically examined in accordance with Appendix
12 of Section VIII. The NDE of welds in Grades WPB,
WPC, WP1, WP11 Class 1, WP11 Class 2, WP11
Class 3, WP12 Class 1, WP12 Class 2, and WPR may
be performed either prior to or after forming. NDE of
welds in Grades WP5, WP9, WP91, WP22 Class 1,
and WP22 Class 3 shall be done after forming.
5.4 Personnel performing NDE examinations shall
be qualified in accordance with SNT-TC-1A.
5.5 The welded joints of the fittings shall be finished
in accordance with the requirements of Paragraph UW-
35 (a) of ASME Section VIII, Division 1.
I hope this will clear your doubt.
Mukesh0861 (1); Qwack (1); Tornado (1); Whitephone (2)
