Previous in Forum: Mixing Up Tube-Fittings   Next in Forum: LP Heater in Condenser
13 comments
Air Compressor Recomendation
07/18/2011 11:20 PM
Im new to the site so i apologize if i do somthing wrong. But I need to know if there is a VERY portable air compressor...like one that i can carry around and use. Very very portable battery and tank and all that if anybody knows of one please help out thanks!
Re: Air compressor recomendation
07/18/2011 11:44 PM
There are several inexpensive compressors that can be powered from a 12-volt car cigarette lighter socket. You may need to experiment with battery size (ampere-hours) to see what will suffice.
07/19/2011 1:42 AM
Ohhhhh yea good thought like a motercycle battery. Yea il do some google-ing on 12v's
Good Answers: 18
07/19/2011 3:01 AM
Hi,
It very much depends what you want to do with the compressor? Can you give us an idea?
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
07/19/2011 4:02 AM
Half-a-dozen appeared brand-new and unused on the market stall on Saturday in the town of Downham Market for £9GBP each. One would fit into a large coat pocket.
Re: Air Compressor Recomendation
07/19/2011 3:01 PM
How about a simple hand-operated bike pump?
What is the application exactly?
Anonymous Poster #2
07/20/2011 10:08 AM
GA - that was my first thought too!
Location: Ground Zero of the Pompous and self important....Washington DC
Re: Air Compressor Recommendation
07/19/2011 10:36 PM
How are you planning on using the compressor, application means everything before anyone can make a recommendation.
07/20/2011 12:02 PM
Thank you, should have been comment #1.
Good Answers: 15
07/19/2011 11:52 PM
In the US we have retail store that sells small portable metal bottle of compressed gas used to drive air tools like nailer's, grinders. portable compressed gas
For every action, there is an equal and opposite criticism.
07/20/2011 6:36 AM
This really depends upon your application and how big your need is. There are lots of portable air compressors, some very small which plug into a cigarette lighter and some that are bigger and plug into the wall. Even most larger ones for a home or shop have wheels on them and can be moved around. You can also store air in a separate tank and just move the tank around from location to location.
Good Answers: 18
07/21/2011 3:09 AM
How about a reply to the questions?
Popular Science - Weaponology - New Member India - Member - New Member
07/22/2011 5:38 AM
Features:
  • High Power Model of 12V Car Electric Air
  • Compressor Tyre Pump - Tyre Inflator
  • High Power Model 300PSIhas a Extra High Power Motor for Better Inflation power + Stronger Outer Body +
  • Long air Pipe
  • Simply use this for fast & easy inflation of car tyres"
  • No strength required for pumping air as it is all electronic & is powered directly from your car battery
  • Perfect for anyone who wants a ease while inflating a tyre
  • Time saving as compared to mechanical pump
    Quick operation
  • Very Compact and easy to store in car dicky
  • Robust and Durable Design
  • Powered by your car cigarette lighter slot / Switch
  • Easy to use - just plug into your car cigarette lighter for power, slip universal adapter over tire valve and you are ready to inflate
  • An invaluable kit for the motorist, no need to be stranded if you have a puncture, simply plug into your car cigarette lighter & place the nozzle over the tire valve.
  • This inflator has a pressure gauge that reads in lb/in and kg/cm bar
  • Compact inflator, plugs into your car cigarette lighter for the easy inflation of car or bicycle tyres, sports balls, airbeds and other inflatable, comes with a selection of adapters
Specifications :
  • 30 Pressure hose with lock 10ft
  • 2 nozzle adapters and sports needle
  • Perfect for cars, bikes. And inflatable
  • Excellent for roadside emergencies
07/22/2011 5:41 AM
Sorry ! i can`t copy and paste image here. visit
http://shopping.rediff.com/product/00psi-12v-car-electric-air-compressor-tyre-pump/10838369
Anonymous Poster (1); Beenaround (1); jack of all trades (1); jesw55 (2); Jim Cartwright (1); Onthewaytotheforum... (1); PWSlack (1); sanjaykangralkar (2); Smoothy (1); Tornado (1)
