Previous in Forum: HT Motors   Next in Forum: ABB Interview Question
8 comments
Why Do We Measure Only Insulation Resistance Using aMmegger ??
07/22/2011 2:11 AM
Why do we use only insulation resistance in megger why not insulation reactance due inductance or capacitance..............and why only dc current is injected in a megger
Re: why do we measure only insulation resistance using a megger ??
07/22/2011 2:20 AM
Does insulation, by itself, even have inductance or capacitance?
07/22/2011 2:26 AM
if capacitance can exist between power lines and earth and inductance can exist on transmission lines then why can inductance or capacitance be present in insulations
07/22/2011 3:55 AM
<sigh> Why would one need to know?
07/22/2011 4:35 AM
Insultation resistance(I.R) is checked solely for safety of personal...it is based on sheathing or coating of rubber or plastic... Which(I.R) usually deteriorates with ageing or temperature... By using dc Issue of Capacitance or inductance don't stand here because the cable capacitance issue limits the length and power carrying capacity of AC cables. DC cables have no such limitation, and are essentially bound by only Ohm's Law. May be that's why to simplify dc is used...
Life is what one makes of it
07/22/2011 5:28 AM
OP
why do we use only insulation resistance in megger why not insulation reactance due inductance or capacitance..............and why only dc current is injected in a megger
A megger is used and to find out what and why? will answer your question, both the parts.
KS- I don't know why you have put your post OT. Only the inadvertent error that has cropped in is
DC cables currents have no such limitation, and are essentially bound by only Ohm's Law
07/23/2011 2:08 AM
Actually it was my 1st post so i was hesitant ...but thanku 4 encouraging me...but dis has to be off topic right
07/23/2011 9:33 AM
Welcome from an old inhabitant. Sorry i didn't see you are greenhorn here .
1. Don't post Offtopic a post unless you thing you are not answering to the query. here you were so it was not OT.
2. Your answer may be correct (you know it) then just confidently post it. In case you are not sure or are guessing, and there are chances that you are wrong, put IMHO (In my humble opinion) some where, preferably beginning or end. So that the reader don't take it as 100% on it's face value.
3. Even when you get an answer from CR4 or other sites. Please crosschek once. It might be wrong. Though what I have found good about CR4 is that people go through and correct the minor mistakes (or even major ones) when the find one.
4. Some correct it with barbs (I don't like/recommend unless it is too totally wrong and wild guess) some one more politically correct way. take both in your stride.
5. Don't use SMS language, almost 90% (I would have said 100 but as a statistician that's not possible) of us old timers don't like that, to the point of almost hatred.
thanku 4 becomes thank you for . It doesn't take that much extra time, but saves some potential heartache (for you)
6. there will be some arguments that are serious to the point of... (especially a few members unnamed since they may find it, you may though if you continue long enough in the site, especially the general area) rest are innocuous banter.
7. Avoid bathbreaking technique (we call BBT) like red hot iron, else..
8. No CAPITALS capitals they are strictly no no here and are considered to be shouting
9. In case you think it is off topic and it is not (or you are too totally wrong) you would any way be marked Offtopic by members (at least 2 required it to get a real OT grade)
These are unwritten codes of conduct the tottering ancients here follow (To avoid raising heckles I am one too) except the 7th one of course.
This post is OT but I am keeping it on so that you may see how the OT system works.
Re: Why Do We Measure Only Insulation Resistance Using aMmegger ??
07/23/2011 3:10 AM
Simply because even you can measure capacitance/inductance/reactance of insulation, the values are not significant at all in electrical power distribution.
Megger meter applies voltage , not current, but read current to give ohmic value.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Register to Reply 8 comments
Anonymous Poster (2); bravo88 (1); geetartha (1); keyser Soze (2); PWSlack (1); Tornado (1)
