Previous in Forum: Cooling Tower Of Power Plant   Next in Forum: LPG Pressure??
10 comments
Patching a Punctured And Holed Collaplisible Water Tank
07/24/2011 2:50 AM
Hello
i hope all is well .
we have a collapsible tank, needs repair, since it was damaged in a small area due to pulling and needs patching.
How can it patched. Where can i buy appropriate material or repair kit?
Re: Patching a punctured and holed collaplisible water tank
07/24/2011 2:54 AM
How about a tire/tyre patch kit from your local bike shop/shoppe?
Good Answers: 53
Re: Patching a punctured and holed collapsible water tank
07/24/2011 3:05 AM
You need to define material first.
Then get a pieces of same material to patch up.
Get a right Adhesive/solvent/solution that can join patch on tank, Or you can try welding it thermally. And make double patching inside and outside both, If not possible double then make sure you do it inside.
07/24/2011 10:23 AM
Nah, we don't need to know the material to produce guesses. We love to make up all sorts of wild scenarios to fit our answers.
Since this is non-potable water used in cooling an internal combustion engine, simple duct tape can be used to seal this overflow container until a more permanent repair can be done.
See, not only was that not difficult, it was also fun.
Good Answers: 53
07/24/2011 12:15 PM
Good Answers: 146
07/24/2011 8:31 PM
His collapsible tank is just like the one I used to have for camping, and I hate to tell you, that first leak is the sign of doom.
Patch all you like, with whatever you like, fill with water, observe that it held for 20 seconds although it does seem to be sweating a little. Then pick it up to move it and it's all over. Literally. Good fun for a hot day.
My advice is, go back to the dollar store and buy yourself a new one.
incus opella
07/25/2011 12:04 AM
yeah those tanks get brittle fast if left empty for any lenght of time
Good Answers: 74
Re: Patching a Punctured And Holed Collaplisible Water Tank
07/24/2011 6:11 PM
Just scale up, Ky.
The Twain Has Met
07/25/2011 12:06 AM
remember the old tire plugs they use to make that had a large thick patch with a tail on it you installed from the inside of the tire outward ?
Pulling those tails thru holes in Radial Tires was a hard job
07/24/2011 11:59 PM
use an old inner tube till you can find someone with atleast a river raft material repair kit -- it is thicker
07/25/2011 12:01 AM
oh excuse me had a kid in my ear missed the water tank part.
Call up and find someone that has River Rafts -- then get a repair kit from them -- or you can make a temp patch from a Inner tube -- stop by a truck tire store and get an old tube out of their trash !
Register to Reply 10 comments
artsmith (1); dadw5boys (4); ky (1); rakesh_semwal (2); redfred (1); Tornado (1)
