Previous in Forum: Water Suddenly Appeared in Middle of Room   Next in Forum: Concrete Honeycombing
17 comments
Pipe Sizing for Hydro Station
07/26/2011 12:40 PM
For a Hydro Station , A pipe of 1.8 Km is Used with downward inclination having gradient of 1:1000. The pressure is considered to be 2 bars and flow rate is 17 cum/sec. I need to find diameter of the pipe???? Quite confused.......I need to know are the parameters insufficient (considering hydro power station) or How can i find the size????
Plzzzz Help!!!!!!!!!!!!
Re: Pipe Sizing for Hydro Station
07/26/2011 12:59 PM
This sounds like something you should have learned in school.
There are a number of free pipe sizing calculators on the web.
Good Luck.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
07/26/2011 1:02 PM
It all depends on what your acceptable headlosses are and a what you set as an acceptable pipe velocity....
Sometimes my thoughts are in a degree of order so high even I don't get it...
Good Answers: 101
07/26/2011 1:30 PM
Making some assumptions, I get roughly 3.3-3.5 meters in Diameter. This is based on:
  • Flow-rate of 17m3/S
  • Velocity of 2 M/S
  • Fluid Density of 1000Kg/M3
This puts the pipe at 3289.76mm Diameter, with an area of 8,500,000mm2.
I have not factored in the actual gradient, to figure out the true velocity, I made a quick assumption which may or may not be even in the same state as the ball park .
(Don't trust everything you read on the Internet)
07/26/2011 1:56 PM
Hmmnmnmm.
I thought it was a trick question. I put down 1.8 kilometers on my homework.
07/26/2011 2:10 PM
It's not a trick question, it's a joke. After looking at the OP's history, I'm convinced it's homework, copied directly from the book.
There I go again. Ragging on innocent posters.
07/26/2011 2:15 PM
Do your own homework! Do your own homework!
07/26/2011 1:59 PM
I tried i got 1.5 to 2 mtrs but do you think it is practically applicable??????????...............it seems simple but i gues it is not?..........point about the head losses considered ,...........but the velocity we need to find out............
Good Answers: 38
07/26/2011 2:15 PM
We haven't any idea because we have no clue as to budget, site conditions, etc.
This is because you haven't defined exactly what your constraints are. It is a simple problem if you know what you want/need.
07/26/2011 5:54 PM
There would seem to be a fundamental error in the original data.
If the downward slope is 1m fall per 1000 run, then the head would only be 1.8m. (That is actually less thanthe pipe diameter suggested by some others already.)
If the downward slope is 1m traverse for 1000m fall, then somewhere in the world he has a 1.8km waterfall.
2 bar presure implies at least 20m fall, so first option is out (since the change in elevation is less than this) and the second optionis out since pressure would be significantly higher than nominated.
Please look at your request again and clarify.
07/27/2011 4:13 AM
hey thnks for the reply........1.8 m is the head.....but parameters (specifically regarding the pressure) which i received from my boss were doubtful (a Non technical person). I m finding it difficult to convince him ......he jst needs size of the pipe.....Hope he undrstands ...anyways thnks for the reply!!!!!!!!!!!!!!!!
07/27/2011 9:09 AM
This is hopeless.
The blind, leading the blind.
Hire a consultant who knows what he's doing.
07/27/2011 12:55 AM
Boy, would I ever like to attain a flow rate of 17 cum/sec.
07/27/2011 10:54 AM
I'd vote you off color, if such a catagory existed.
07/27/2011 6:09 AM
Just based on Manning's Equation and a roughness coefficient of 0.015 I come up with a diameter of 3.501 meters but the question is somewhat ambiguous as I am not sure what role this pipe plays in the hydro power station. Is it simply to convey the flow to the station or is power somehow being generated across the fall? It does not seem possible as the pressure is approximately equal to the head difference across the length of the pipe.
If you want to know what God thinks of money, just look at the people he gave it to. - Dorothy Parker
Good Answers: 179
07/27/2011 11:56 AM
You need to use a nomograph to get an estimated pipe size for starters, then refine it with calculations....
BUT, assuming that the pipe inlet is submerged you need to know what the total head of water (water depth) is above the pipe inlet centerline at the dam face, plus inlet conditions, outlet conditions (submerged vs. un-submerged vs. partial water depth vs. free fall?), and the type of pipe material in order to ascertain a friction coefficient (use aged pipe value for future conditions, not a new pipe f).
Use Bernoulli's Theorem to calculate the most efficient pipe diameter, by trial and error over several reiterations.
[still seems to me a "homework" problem. If not, the OP should have learned how to do this in Hydraulics class long ago and not on the job.....]
07/29/2011 3:20 AM
If the pipe is 1.8 km long, with a slope of 1:1000, then the difference in elevation is only 1.8 M. Where does the 2 bar come from? A drawing of the pipe and the assumed water levels would help.
Why such a long pipe in the first place?
10/07/2024 9:09 AM
A rule-of-thumb for liquid pipework: Consider only average velocity -
  • If it is more than 3m/sec then the diameter is too small.
  • If it is less than 1m/sec then the diameter is too big.
The rest is calculation. Invitation declined.
Register to Reply 17 comments
brendan4 (2); CaptMoosie (1); ChaoticIntellect (2); d_m_rosenberg (1); Doorman (2); Just an Engineer (1); lyn (4); PWSlack (1); RVZ717 (1); Tornado (2)
