Previous in Forum: Semiconductor Doping Process   Next in Forum: Dike Wall
30 comments
High Temp Flat Plate
07/26/2011 5:50 PM
What type of plate steel should be used in an environment that sees temp's constantly of 250-350 degrees Fahrenheit? I need to minimize warping. The heat source will be below the steel and the plate will not be fastened down. Dimensions of the plate are 30 x 36 x .5 inches. Thanks
Re: High Temp Flat Plate
07/26/2011 6:22 PM
I'd go with cast iron if you can.
07/26/2011 7:11 PM
You might consider looking for something with a low coefficient of thermal expansion.
All the heat on one side will warp something for sure. Should be fairly simple to model if you can figure the temperature differential.
MatWeb can help. (nae)
Good Answers: 143
07/26/2011 7:47 PM
I think kramarat is right on this. Large pieces of steel-any kind of steel-will warp more than cast iron; however, if you're bound to use steel, soak it at 500 °F or so for a few days, then roll it flat. If you can get most of the stresses out, that'll go a long way. Talk to your local heat treater to get the right temperature; I'm just guestimating.
07/26/2011 8:46 PM
I'm not sure what kind of steel it is, but I just had an image of a short order cook flipping burgers on a big griddle.
Maybe a restaurant supply house would have something made to order.
Good Answers: 53
07/26/2011 10:58 PM
Cast Iron looks best choice as suggested before, But beside the material selection if you can provide cross holes across its length and width, this can help you to get temp equilibrium in quick time and will provide extra stiffness to plate.
07/28/2011 12:14 AM
Rakesh, you wrote,
'...cross holes its along length and width...... will provide extra stiffness to plate...'
Could you please elaborate?
Good Answers: 53
07/28/2011 12:36 AM
Yes, Think it the way.
Hollow pipes and tubes are less prone to bending than of solid rods.
07/28/2011 8:02 AM
Holes will not increase it's stiffness, they may increase it's strength to weight ratio, which does not seem to be an issue here.
Good Answers: 53
07/28/2011 12:28 PM
Pipe or anything that is hollow is always tough to rap/bend in compression of solids. On that ground which one is more stiff? Providing holes are similar to that of making ribs on rare side of plate and then hiding those ribs by another plate,
07/28/2011 3:02 PM
In either case, the pipe or hidden-rib plate example, in most cases there will not be a significant difference in stiffness as compared to a solid peice of the same material and same outside dimensions..
...that is until the point when the pipe wall or plate wall of the hollow structure buckles.
A shape with holes is not inherently more stiff than the same shape without holes.
07/28/2011 4:48 PM
on that ground, the solid is more stiff
07/27/2011 1:27 AM
That sounds about right for 3.5 dozen eggs over medium.
07/27/2011 7:22 AM
Does it have to be metal?
I guess I think about food a lot. I just thought of the pizza stones that are used to bake pizza in very hot pizza ovens.
07/28/2011 8:41 AM
How about a cast iron waffle plate in reverse?
bioramani
07/28/2011 3:29 AM
I will advice that you use 310H austenitic stainless steel. This material has a high chromiun and nickel content and has the ability to withstand high temperatures.
it can stand oxidation and deformation and is used in furnaces etc. It is available in plates strips and bars.
see ASTM A240 for chemical and physical properties. I wish you the best.
Chike Nwachukwu
Good Answers: 109
07/28/2011 3:50 AM
Temperature is not the culprit of warping but temperature gradients:
gradients in plane and vertical to the plane will introduce thermal deformation and also stress.
If the material has a too low yield stress at the highest operating temperature there will be permanent deformation else only temporal.
A good thermal conductivity is beneficial as there will be only smaller thermal gradients with these materials.
So stainless steels (if austenitic) are bad as thermal conductivity is low.
Ball bearing steels are good as high strength, good thermal conductivity and slightly elevated temperatures are a typical must of these. Similar any other tool steel.
Think about ceramics or natural stones:
soap stone may be ideal,
very good and not too expensive is aluminum oxide and silicon carbide if produced as grinding wheels,
aluminum nitride, silicon carbide and silicon nitride are near ideal but cost will be tremendous.
To be done: estimate the temperature gradient across your 0.5" plate.
Calculate bending of a strip of your material by this temperature gradient and its thermal expansion. Calculate stress with the assumption that there is no bending or warpage, the actual stress will be near 50% of this value.
Two axis stress will lower the actual deformation.
Set a limit for residual warpage after cool down (if wanted).
Look up for the yield strength at your maximum temperature.
Or just try some steel plates that are usable to twice the temperature you want to use.
RHABE
Good Answers: 56
07/28/2011 8:00 AM
Most all of my experience with this issue is limited to fully vitrified materials that have been ground and polished to an accuracy of 1/30 of a wave of light or better, in the visible spectrum.
When the substrate is not at the same temperature as the surrounding environment it's utility as an optical instrument is seriously compromised, until it reaches thermal equilibrium. When that is achieved, the accuracy returns.
This suggests that perhaps you might consider Blanchard grinding the plate, while it is heated to the temperature it will see when used. It also suggests that a material with a low coefficient of thermal expansion be chosen.
There are substrates that have a zero coefficient of thermal expansion (Zerodur being just one) but the costs are prohibitive.
You have not stated what degree of flatness is needed. If repeatability is an issue, then it suggests that some serious annealing be entertained so as to insure that as the the plate is cycled through its temperature range, that it will always return to the flat state achieved when Blanchard ground.
Clear Skies!
Laughing Jaguar
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
07/28/2011 8:09 AM
I'm guessing there is about to be another great invention created right here on CR4 folks, a combination deep space telescope/short order grill setup. The reflective coating (applied to a surface with less than 1/30 wavelength flatness) also makes an incredible non-stick surface. Party all day, explore all night. Call me crazy, but I also see a wok model coming out.
07/28/2011 3:04 PM
Within a .03" is acceptable. I just do not want to end up with a banana when it heats up.
07/28/2011 9:21 AM
All this talk about food is making me hungry!
Are you opening a restaurant?
07/28/2011 11:45 AM
I have an 8'x10' set of oil heated top and bottom platens, in my lab, which can be heated to 500*F. These are perfect for producing the perfectly balanced, crispy crust, melted cheese pizza. I can set the gapping of the platens to just the right distance to produce the ideal result without the charring effect of infrared. Come on over and we'll bake one he!! of a pizza! BYOB, of course!
Z
“ That which is in locomotion must arrive at the half-way stage before it arrives at the goal. ” Aristotle
07/28/2011 9:49 AM
Boiler plate should do
07/28/2011 10:11 AM
Dear poster
we are a curious lot
what kind of boiler plate and why
07/28/2011 10:37 AM
You have not clearly stated the application so this makes analysis more difficult. I understand there is a heat source below this plate, the plate itself is supported but not secured. Is the chamber in which this plate is suspended larger than the plate (in which case the heat can move around the plate to the top side as well) or the same size (in which case the heat has to be conducted through the plate to the other side)? Why are you using a plate of this size and thickness? Will the plate be seeing any other loading besides the thermal loading? What purpose does the plate serve, other than separating the heat source from the topside of the plate? Are there any other chemical limitations that would restrict the plates material of construction?
In general you should be fine using conventional carbon steel plate (ASTM A36 or ASTM A516-70) as carbon steel has acceptable coefficients of thermal expansion in this temperature range. Some expansion is to be expected, but if the plate is only suspended and not secured on the edges, there should be mostly linear expansion and very little warpage. If, on the other hand, the plate is secured along the edges, or movement is limited by sidewalls, then the expansion will result in some warpage of the plate. However, 30" x 36" x 1/2" thick plate will take a lot of heat before warping. I would not use any form of stainless steel as its coefficient of thermal expansion is much higher than that of carbon steel.
If you can't do it right the first time ... do it wrong, then let the professionals fix it.
07/28/2011 2:55 PM
The plate is the same size as the support below it and the sides are not restricted. The plate is protecting the components that are creating the heat. I could go thinner than 1/2 inch, but I wanted something with some weight so it would stay in one spot.
07/28/2011 3:06 PM
Thermal expansion of carbon steel is 0.0226" per foot at 350 deg F and 0.0140" per foot at 250 deg F. Therefore, expansion of your 30" x 36" plate would be about 1/16" all around at 350 deg F (0.0565" in short direction and 0.0678" in longer direction). Not significant as long as sides are not restricted. Sag due to temperature should be inconsequential as well.
07/28/2011 11:36 AM
H grade tool steel may be adequate for your application. Our company uses it daily for hot molding of plastics and thermosets. There are several types, so without knowing what your application is, it is not possible to make a recommendation.
Z
07/28/2011 5:10 PM
I'm with the folks the suggest you buy your plate/cooktop from a known supplier of this type equipment, it'll be cheaper than reinventing, reinventing never pays. And I don't think it's going to come as a flat sheet either. Most likely it will be a stress relieved fabrication of cast iron and steel. But if your hell bent on doing it yourself, a piece of pickled hot roll wouldn't be very expensive and it'd already be stress relieved. If you heated it slowly up to temp, it shouldn't move much, but it'll be more than .03 out to start. O'yeah, get the plate flame cut not sheared to minimize the out of flatness.
Good luck!
Good Answers: 117
07/29/2011 11:37 AM
Just buy the wood stove.
08/01/2011 5:49 AM
The plate is not likely to distort, the way you have described. As a precaution you may rest the plate on two round bars placed from edges at @ .027 x Length distance.
if you are a managment professional or youth who wants to start business contact for free help for your project including financial assistance through NGO in and around Pune India
Register to Reply 30 comments
bioramani (1); Breis (2); Charlie2 (1); Chike Nwachukwu (1); dennis_gK1 (1); kirannawathe (1); kramarat (3); Laughing Jaguar (1); lyn (1); Onthewaytotheforum... (1); PFR (4); rakesh_semwal (3); RHABE (1); Tornado (1); truth is not a compromise (2); TVP45 (1); YesMAM (2); Yusef1 (1); zenos paradox (2)
