Previous in Forum: Temperature Classes   Next in Forum: final year project
Instrumentation for Anhydrous Ammonia Tank
07/28/2011 1:21 AM
Hi
please let me know that the type of material used in instrumentation to be attached with an anhydrous ammonia tank can be Carbon steel. can i an select gate valves, flanges, pressure safety valve, pressure, temperature and level gauge of carbon steel.
the tank material is carbon steel (is it ok)
some body told me that the material of tank and instrumentaion can not be carbon steel it should be ss.
Re: instrumentation fo anhydrous ammonia tank
07/28/2011 6:10 AM
Instrumentation is rarely made in carbon steel, as carbon steel deteriorates over time. Such an instrument would soon become useless.
Look at corrosion resistance charts to determine material/fluid compatibilities. One such chart is the Cole-Parmer materials compatibility database, which any internet search engine will find.
Re: Instrumentation for Anhydrous Ammonia Tank
07/29/2011 12:42 AM
Ammonia is not corrosive to carbon steel. For vessels, SA516-70 is a common plate, SA285-C has been used; and smaller vessels can be made of pipe, such as SA53-B or SA106.
Valves can be made of steel bar stock, cast ductile iron, etc. (but not plain-jane cast iron). Trim is likely to be SS; PTFE and neoprene are good elastomers. Gate and butterfly valves are not generally used; globe and ball valves are most common.
Wetted instrument components and tubing are commonly SS, more from the standpoint of external (atmospheric) corrosion rather than internal.
Engineering Fields - Chemical Engineering - New Member
07/29/2011 5:21 AM
Hi Kazengg
By this time you have your answer from Tornado.For ammonia service you can very much use carbon steel.For both ambient temp storage (Pressurised) or refrigerated storage(Atmospheric) you can use SA516-70 steel plate.
Only thing you should remember that you should not use Zn or Cu alloys in ammonia service.
For instrument tubing you should use stainless steel.
07/29/2011 10:21 AM
kazengg, I would like to inform you of the following:
1.- If you are not sure of the materials, pelase hire or contract a materials engineer, so that you can avoid major problems in the future. Doing engineering and construction without having a proper background can lead to major problems, even legal problems.
2.- Check the corrosion tables and other information and see the link here http://www.rmtech.net/Anhydrous%20Ammonia.htm.
3.- The product based on concentration can be deadly so the materials of construction are very important, and make sure that as little water as possible gets in contact because then it can be very corrosive.
4.- Most instrumentation uses stainless steel and even with plastic coated elements, so the instrumentation should not be a problem.
Again, handling and working with toxic chemicals can lead to all kinds of problems, so hire experts to design it, or of course enjoy the difficulties.
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
07/29/2011 8:19 PM
You sound unfamiliar in a potentially dangerous industry so "Do the Google on the internet machine". You can find a wealth of information through these companies:
Vilter, Danfoss, Refrigerating Specialties (Parker), Shank, Phillips, Cornell, Viking, Mycom, FES, Sporlan, Hansen Technologies, York, Dunham-Bush, Allen-Bradley, Morris & Associates, Vogt Evapco, Frick, GEA, and Henry. Also check out these organizations; IIAR, ASHRAE, and RETA
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
manzoor ahmad tarafdar (1); markar (1); PWSlack (1); Tornado (1); vargaalex (1)
