Previous in Forum: Generator Engine Power   Next in Forum: Hydrotest Pressure for Natural Gas Piping
1/3 HP Motor
07/28/2011 6:30 PM
I have two 1/3 HP motor's in parallel, 480V, 3 ph, I can not run both at some time with out getting an overload. When I run one seperately, I am drawing 6-7 A no load.
My power supply is coming in on a 1000' of #12, my thoughts are to much V drop but calcs show to be with in 10%.
Any Ideas?
Re: 1/3 HP Motor
07/29/2011 1:25 AM
That doesn't compute; a 1/3 hp motor on 480/3 should draw about 0.8A full load current. It also sounds as though the two motors are paralleled onto one overload device, which would not normally be correct.
Re: 1/3 HP Motor
08/01/2011 8:30 AM
Yes, they are paralleled, but with two overload devices. The motors are rated for 6 amps, I believe they typically run w/ load around 2 A, but not for certain.
Re: 1/3 HP Motor
08/01/2011 9:23 AM
I appologize, with further research I find you are correct. My FLA is 0.85A. I was mis informed, this is a hand me down project and information is proving more than difficult to come by. The tech said when running one motor they read 6-7 A. and I am now wondering if they only isolated one motor and possibly that motor has a short?
Re: 1/3 HP Motor
07/29/2011 11:29 AM
How hot does that 1000' of # 12 wire get? Can you hold it in your hand?
I'm with Tornado on this one.
Re: 1/3 HP Motor
08/01/2011 9:06 AM
Its not melting, Its warm. The motor's run around 2 amps under load.
Hazo (3); lyn (1); Tornado (1)
