Previous in Forum: Can Compressed Air Convert in to Rotational Motion?   Next in Forum: Capacity of Lobe Compressor Required to Convey Solid
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
Rotor Losses
07/29/2011 2:08 AM
Hello everybody,
In a Brushless Permanent Magnet motor,
How to calculate the losses occur in rotor containing Permanent magnets?
you need to go, to get something
Re: Rotor losses
07/29/2011 3:50 AM
Mechanical losses (Due to bearings)
Windage losses (depends upon the geometry, RPM, a bit complicated though possible)
Re: Rotor losses
07/29/2011 5:54 AM
(Volts multiplied by amps) - (shaft torque multiplied by angular velocity) = losses.
Re: Rotor losses
07/29/2011 6:00 AM
It is a piece of Permanent magnet ratating , there is no loss by the magnet.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Register to Reply 3 comments
Anonymous Poster (1); bravo88 (1); PWSlack (1)
