Previous in Forum: Synchronous Motor Load   Next in Forum: 110kv SF6 Breaker
DG Coolant
08/01/2011 11:36 PM
what is the chemical which is mixed with water... that is added to DIESEL GENERATOR radiator as coolant..????
Re: DG coolant
08/01/2011 11:57 PM
glycol. It is only needed if you have freezing condition.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Re: DG coolant
08/02/2011 12:00 AM
More specifically, ethylene glycol. Some formulations include anticorrosion additives, and can thus be useful in nonfreezing situations. In addition, EG also raises the boiling point of the mixture.
Re: DG coolant
08/02/2011 12:18 AM
may i knw the propotion of glycol/ethylene glycol, which is added to water...????? i want the ratio .....???? i mean liters of glycol per liters of water..
Re: DG coolant
08/02/2011 12:26 AM
It depends on how cold the mixture might become. A table or chart of EG/water mixtures will give the freezing point of various ratios; you could select a ratio that has a freezing point of say 10°C below the lowest expected temperature at the DG's locale.
Re: DG coolant
08/02/2011 3:49 AM
In this part of the world, 30%. In Singapore, none is needed.
Re: DG coolant
08/02/2011 2:56 AM
You got the answer, but I think the real question is how much glycol in coolant you have to add ?
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Re: DG coolant
08/02/2011 3:03 AM
Glycol...
One system
Register to Reply 7 comments
bravo88 (1); loadshare (1); mohsinhamid (1); Pandu78 (1); PWSlack (1); Tornado (2)
